This involves removing the DPF and taking out the internals and welding the top back on, we then map out the sensors to stop any lights appearing on the dash.. As part of the service I`ll also remap the vehicle for no extra cost
If you remove a DPF then yes it would fail, but at the moment it is a visual check so long as the canister is still there then it would pass. We only remove the internals and put the DPF canister back on.
