Help me with my next upgrade
mechanic69
Gold Supporter
would you reckon a new map will increase HP? i did get it mapped before i changed the hpfp.
i have considered to stop with the engine mods, and go for some cosmetics. like painting the rims and calipers.
i also looked at a new front grill, im not so sure about the quality tho. but
mine is a bit "ugly" from having passed the 120k km mark.
http://www.xenonz.co.uk/store/p501/AUDI_A3_/_S3_2009__RS3_front_grill_gloss_black.html
I had one of those for a while, pretty good replica, couldn’t fault it, but had to swap it out for an OEM RS3 grille when a second hand one came up.
Would a recommend a custom remap to make most of the engine upgrades
kaspar
is there like a noticeable difference comparing it to the oem one?
yea i knew the remap was more or less necessary
thx
mechanic69
Gold Supporter
thx
I think there their the best replicas available, I couldn’t fault it, I just new it wasn’t real so it had to go eventually
nluk100
If all you're doing is changing the intercooler and the RS4 fpv then you probably won't benefit too much from a map tweak. If you haven't already, invest in a decent set of ARBs.
nluk100
i changed the hpfp, but i got the map done before doing so.
Aah, ok, then you will definitely benefit from a map tweak, but install the RS4 valve first. I have a AKS Tuning valve rated for upto 175Bar up for sale if you wanted to get the most out of your map tweak? Who did your map?
kaspar
i did actually consider doing that before hand.. it shouldnt take to long installing the rs4 valve am i right?
unfortunately i live in denmark, but the ones who did it ensure me that it could get pushed further, but not with the oem hpfp.
will the rs4 valve do anything hp wise?
nluk100
You can actually fit the rs4 valve without taking the manifold off - it's a bit tricky but possible. As far as hp, it will allow your tuner to run up to 130Bar fuel pressure which will release more hp. You can actually run up to around 150Bar without any issues.
kaspar
i just ordered one, so ill be remapping my car with it. ill post when i get it done :) hopefully it will increase my hp
thank you!
also, ill probably be getting one of those grilles within a few months time
nluk100
That's great! The dyno is probably a bit optimistic but as long as you see an increase and the car feels good then that's all that matters. Did you do your clutch?
kaspar
im running shell v-power 99 aswell.
but my car is running so smooth now, and it pulls like never before. the difference is very noticeable
nope still running with stock clutch
kaspar
S3
Audia3bitch
Flutter doesn't change
Mine flutters at low revs sounds awsome.. one off my fave mods gfb say that its will flutter at low revs but its fine,, i rate the gfbdv+ felt so much moor responsive after i changed it from the stock one its a must have
Audia3bitch
If you dip the accelerator back down after you accelerate you can make it flutter on tap i mite do a video clip sounds awsome!!!!!!! Did you feeal how responsive the car was after changing out the stock???! Gfb make some deccent parts man
kaspar
yea the difference is very noticeable. the car feels alot more responsive, without a doubt
kaspar
Nice looking whip for sure. The new grill is a treat. I followed one of the members and switched to the blackout fog grill and had it painted gloss black. It matches the honeycomb grill and gives it a nice new pop of style.
ahh yes, ive seen that one.
kaspar
i had the revo cai installed + the increase in boost from the map seems to have increased it
P
Peto Pedro
Guest
Hello everyone
im in doubt whether i should upgrade my car or just keep it as it is
currently running with loba hpfp, full milltek sportback and revo cai.
my car is pushing 354+ hp
what would be the next "go to" upgrade?
im only looking for engine upgrades ;)
none ! just stop messin .. u have super car !
paddy
Just as a matter of interest my DV was the later none diaphragm type but was failing. It had gone down hill for a while and while i knew something was wrong it wasnt obvious what. the slower the car got the louder the fart on gear changes got. In the end more luck that judgment i changed to a DV+ and it totally transformed the car back to a quick little thing for an audi shopping trolley :) now i can feel the traction control cutting in in 1st and 2nd in the dry.....Fart from the exhaust on gear changes has completely gone though now.
kaspar
i was wondering about getting my IC upgraded to a wagner one
how big a difference is there, comparing it to the stock one?
will there be any hp gains after a remap?
paddy
Will be getting mine done this month so i will let you know. It should give a slightly better flow and cue boost leaks from plastic ic's however its more about getting the Turbo to run more efficiently at higher temps than any gains from a normal cold day reading i think. If you are running 384bhp then i cant see you getting gains TBH. I am only doing mine because i have the later plastic IC.
mechanic69
Gold Supporter
I went for the Wagner and all the CTS Pipes from turbo to inlet manifold, really opens up the air intake system and maxes airflow, needs a remap to optimise fuel settings with the extra air, worthwhile mod, I felt the engine was more responsive after fitting but can’t give any advice on numbers.
Bit of a ****** to fit as you have to have the entire front end off and refill coolant etc, also my air con pipes wouldn’t fit back as the ic is so big it takes all the space.
Still a worthy mod but probably later on the list
kaspar
i should probably upgrade the IC + the cts pipes before getting the remap done to get the most out of it
looking at the throttle pipe, i assume it fits the s3 8p, eventhough it doesnt say?
paddy
You will need a bigger turbo for the next remap so then you will need a IC
mechanic69
Gold Supporter
There is a cts throttle pipe, replaces that **** restrictive oem unit
mechanic69
Gold Supporter
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
These for the interior if you haven't already got a nice little addition
mechanic69
Gold Supporter
Nice seats loose the wood
