someone please stop me going mad, I brought an v reg s3 which was lowered, changed everything back to standard got springs and shocks from an 02 s3 fitted with new top mounts bearings ect, noticed that the drivers wheel hub was somehow bent which caused the brake carrier to rub on the back of the break disc, so with my wisdom changed the hub with the one I got from the 02 s3. Fitted fine and looked perfect, however the passenger side sits a lot higher than the drivers side changed the strut and spring for new incase these was damaged in anyway however still the same Only thing different is the hub? Can this really cause this much trouble??
