Help!! Fuel hose disappeared?!
ChristianCameron Dec 18, 2014
  1. ChristianCameron
    ChristianCameron Member
    47
    29
    I have a 2007 A4 1.8t Avant and I had it Revo'd stage one last Saturday. Its been an absolute nightmare ever since.
    First of all one of the coilpacks packed in, which is fine, got 2.0t coilpacks with adaptors fitted yesterday...haven't been able to try them out yet though because on Monday (Driving it with a misfire for a couple of days and running very rich at that) pulling into work, the car died and wouldn't start. I was able to park it at work and last night I spend a good hour trying to find out what was wrong.
    There was petrol all over the ground so I had a bad leak, that was obvious. Upon pulling off the covers under the drivers side I was able to assess there was no leaks at the fuel filter connections which I thought it was because I changed the fuel filter 20k ago and thought the fuel pressure caused one connector to blow out. But then I found out exactly where it was leaking from. Its hard to explain - basically there are 3 fuel pipes running down the underbody of the car and 2 are connected to the filter fine, this magical 3rd one goes NOWHERE. It ends near the fuel filter but has no bends, no connecting pipe, nothing. It looks like its been cut, but its not, its just open ended as if something goes on it but theres nothing near it? Somebody has mentioned to me a blanker goes on it for the diesel models that has a diesel cooler? Every time I turn the car over it just gushes out of this pipe, some kind of return pipe? Its blowing my mind, I've even started removing the fuel filter to try and see if I can find the pipe that it connects to, maybe it blew backwards with the pressure?
    I'd really appreciate if anyone could take a look at their fuel filter or have nay ideas because I'm quite desperate and distressed at the moment to say the least!
  2. Avatar
    Google AdSense Advertisement
  3. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,845
    187
    This is the B6 forum, not B7. Have you tried blanking the pipe off and starting the car? Other than that, I can't help you further. Someone else will be along shortly I'd guess who may know more.
    Dan
  4. Mike.M
    Mike.M Well-Known Member
    2,510
    171
    Does this help:
  5. pauldazzle
    pauldazzle Well-Known Member
    1,227
    102
    All 3 pipes should be connected to the filter. 2 inlets + 1 out. Sounds like you have a missing extension connector pipe. Parts 28 & 29 in the above schematic.
  6. ChristianCameron
    47
    29
    I know, but it will be the same and for all I know I could get better information from someone who owns a B6 for the sake of limiting my scope to the B7 area
  7. ChristianCameron
    47
    29
    Its at the fuel filter end, is parts 28 and 29 not around the engine block? and surely it couldn't be that bad that that a whole pipe and 2 connectors disappear down the road?
  8. Mike.M
    2,510
    171
    I think a photo from under your car of the area etc will speak a thousand words
  9. ChristianCameron
    47
    29
    I will get some photos tonight but in the meanime I'm thinking the best thing to do is probably see if I can get a look at another a4 around the fuel filter, thanks for your help guys
  10. pauldazzle
    1,227
    102
  11. ChristianCameron
    47
    29
    had a look at that, he only has 2 pipes going from the filter through the cover towards the front of the car, mine ends just behind that cover so I really need to see under that cover!
  12. Avatar
  13. kkbatton
    kkbatton New Member
    Post a few pics of your car. Post a few pics of what you are looking at so we can see
  14. ChristianCameron
    47
    29
    Ok I think I've sussed it...not 100% sure though...Basically I've tracked down all the pipes and understand where they're going, the pipe that is open ended is actually the breather for the carbon cannister and I think the fuel is getting in where only vapour is supposed to get in because the fuel filter has failed. There are 2 inlets and 2 outlets and the fuel going in is going out the wrong outlet...getting a genuine Audi fuel filter on Monday and hoping this will sort it.
  15. jammah
    jammah New Member
    Hi there, did the filter solve your problem?
    I have exactly the same fault
    Cheers!
  16. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User TDi Audi A4 Audi Avant Owner Group quattro
    6,727
    3,207
    This thread was last updated nearly 4 years ago, @ChristianCameron hasn't been on the forum since July so don't expect a quick answer.
    Audib5fan likes this.
  17. ChristianCameron
    47
    29
    I got a notification for jammah's post by email and I've been trying to remember what the problem was all day but I can't! I know it was something very silly to do with the fuel filter but I can't remember what exactly so I'm afraid I'm pretty much no use. I remember the fuel ******* out of the return line because it wasn't going into the engine, it was jump started and that ruined the air suspension management.
