HELP! - error codes after disconnecting battery
pns2007
Moonstone Grey
Hi all,
I've spent the past couple days installing my reversing camera and also the new Audi UTR camer. All has gone well and working.
However, when I reconnected the battery, besides the usual error codes, I've got additional ones. I've cleared all codes and this is what I've been left with :-
Sunday,06,May,2018,15:20:21:20670
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUZZZ8V1H1021265 License Plate: AFTER CAMERA
Mileage: 12161km-7556mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 37 42 44 47 52 55 5F 6C BB
BC
VIN: WAUZZZ8V1H1021265 Mileage: 12161km-7556miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 0100
37-Navigation -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CR HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2508
Revision: 22004001
Coding: 02254012432501092000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM16TDI03004L906056CR 002005
ROD: EV_ECM16TDI_002_VW37.rod
VCID: 7F073B1BE6ADC2BC61-802A
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 049 H HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0906
Revision: 00005026 Serial number: CU501608237597
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW27.rod
VCID: 428172EFD5DF6F544E-8016
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 AR HW: 5Q0 614 517 AG
Component: ESC H62 0642
Revision: 00000000 Serial number: 62256000003684
Coding: 13F18AA224220A6D89790E0640C825C8512450917002A472024100748208420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 0103BDE39059B44C17-8054
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000001028316
Coding: 03100104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 408578E7DBD37D4458-8014
1 Fault Found:
263682 - Exterior Air Quality/Humidity Sensor
B137A 31 [009] - No Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 3
Reset counter: 80
Mileage: 12154 km
Date: 2018.05.06
Time: 14:55:08
Outside air temperature: 23 °C
Voltage terminal 30: 14.2 V
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 253 s
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001623601237
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7EF9C61FE1A7CBB46A-802A
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160722 043 0585
Serial number: 160801183305
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62195435
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H05 0032
Serial number: 21 06 2016 00001101
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY162041LMX
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000066833840
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 HW: 5QA 919 294
Component: PDC 8 KanalH07 0031
Serial number: 000308418616244
Coding: 0530051011
ASAM Dataset: EV_EPHVA18AU3700000 009027
ROD: EV_EPHVA18AU3700000_009_AU37.rod
VCID: 0913A5C3A869FC0C4F-805C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0315
Serial number: 003TDR23G2R-
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002154
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 102588A7CB33CDC488-8044
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 480 002 608 16
Component: SideSensor_Df 001 0887
Serial number: 35700000000CB9FC0E13
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 480 002 608 16
Component: SideSensor_Pf 001 0887
Serial number: 35800000000CCA09ED11
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 480 402 908 16
Component: SideSensor_Dr 000 6149
Serial number: 3510001AD2216EE4E42A
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 402 908 16
Component: SideSensor_Pr 000 6149
Serial number: 3520001B12216EE2468$
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 5 - Part No SW: ----------- HW: 480 400 408 16
Component: FrontSensor_D 001 6149
Serial number: 3550002A9209506271CZ
Coding: 2D2D2D
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 807 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001A521816E6253X
Coding: 2D2D2D
Pedestrian Protection Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 807 16
Component: PedP_Sensor_P 000 6149
Serial number: 22900019921816D165F4
Coding: 2D2D2D
Pedestrian Protection Driver 2:
Subsystem 8 - Part No SW: ----------- HW: 480 002 308 16
Component: PedPSensor_D2 001 0887
Serial number: I0M000000002757DDD1F
Coding: 2D2D2D
Pedestrian Protection Passenger 2:
Subsystem 9 - Part No SW: ----------- HW: 480 002 308 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000D8451ED1E
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 JD HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 05091604400935
Coding: A018
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 050BA9F38471986C2B-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 HW: 8V0 920 790
Component: FBenRDW H13 0045
Coding: 24A51A402B9026000100EA001000000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 79F3D503F889EC8C5F-802C
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 26081610802943
Coding: 030100041F0873005B0002481C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CFDCC17F7BBD9A444-8028
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20160830124655 00513
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803001608242957
2 Faults Found:
131632 - High Beam Assistant Control Module
U1070 00 [009] - No Communication
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 80
Mileage: 12154 km
Date: 2018.05.06
Time: 14:58:22
Supply voltage: Terminal 30: 14.1 V
Terminal 15: On
131692 - No Communications with Undefined Control Module
U1126 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 80
Mileage: 12154 km
Date: 2018.05.06
Time: 14:58:22
Terminal 15: On
Address 20: High Beam Assist.
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 210816EHL1168A
Coding: 005D8A205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 438F77EBCAC5665C45-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Coding: 8107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 458B69F3C4F1586C6B-8010
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0100
Revision: 00000001 Serial number: AUZ8ZAGHX006NFN
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 62C1926F751F0F546E-8036
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 100616EFA05773
Coding: 005D82205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 8V0 907 357 A HW: 7P6 907 357 B
Component: MxB-ECU 001 0230
Revision: -------- Serial number: --------------
Coding: 0ECE02202B130200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU37.rod
VCID: 3E79061FA1270BB42A-806A
1 Fault Found:
13705479 - Databus
U1121 00 [137] - Missing Message
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 80
Mileage: 12154 km
Date: 2018.05.06
Time: 15:00:03
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 035 HW: 8V1 035 035
Component: MU-P-LND-EU 052 0679
Serial number: A698H0G7507984
Coding: 017301010000000011111102000A00332F0026E701700100DE
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU37.rod
VCID: 6FE7EB5BB6CDB23CF1-803A
Data medium:
Subsystem 1 - Part No SW: V03 959 801 PR HW: -----------
Component: ECE 2018 --- 0166
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY2078PR
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BJ HW: 8V0 919 614 BJ
Component: ControlUnit_H H85 0855
Serial number: ALJAL109051600010225
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300012A01000300
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_2CamSysRearPASE.rod
VCID: 306528276B73EDC4A8-8064
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 12154 km
Date: 2018.05.06
Time: 14:41:41
passive
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 160816BHF08863
Coding: 000C82204001040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 160816BHF0885A
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End-------------------------(Elapsed Time: 04:38)--------------------------
Mainly to do withHigh Beam assist and Navigation?
Thanks in anticipation
Neil
KenL
Is the car showing up any faults? Is everything working?
If the car seems fine, I wouldn't worry.
NHN
Site Sponsor
Looks like the cam needs basic setting done to get correct distances etc, calibration as such.
Also hex 2 would be needed for the UDS advisory afaik.
Check the humidity sensor is fitted or decode, I think it does come on the rear view mirror in some cars.
pns2007
Moonstone Grey
Thanks Nigel,
Rear camera will need calibrating and I will get that done when time allows.
The Auto HVAC did clear but has come back on again after a drive. Would the aircon need to be on to clear this?
I can't get my head round the HBA and the Navigation! On a Golf forum on a golf the message "New feature! Extended UDS fault detail is only supported by current gen. interfaces" appears to suggest my cable is not good enough.
http://forums.ross-tech.com/showthr...l-is-only-supported-by-current-gen-interfaces
Seems as though my Genuine registered HEX+CAN isn't good enough for this.
Another cause may be that I've fitted the UTR camera too close to the HBA sensor although I'm sure I used the correct supplied template!
NHN
Site Sponsor
Uds error will be due to using the original hex vcds, you'll need hex 2 or hexnet.
Others may also be down to newer protocols used, find a hex 2 or hexnet user & test the theory or ask support.
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Am not 100% sure as I have not installed one as yet but where does the UTR pick up its power.... from the dome lighting area / connections? If so then it looks like you have disturbed the connections to your HBA and RLHS (rain light and humidity sensor), the latter of which is needed in order for your AirCon to work correctly. New VCDS interface or not you should still be able to communicate with the module in question however the VCDS client being able to "understand" it is a different matter.
Re your camera calibration I would not worry. Calibrated or not it will work the same.
Re your navigation issue, control module 37 is not valid for the MQB platform and needs to be removed from your can gateway installation list.
Re range control, the message is nothing to worry about.
pns2007
Moonstone Grey
Thanks @DJAlix The UTR camera sits alone and basically has 3 wires, a ground, connection to fuse 34 and fuse 4. (presumably constant live and switched live) - no connection to mirror wiring at all.
I'll remove the Navigation from Can Gateway, although I didn't add it in the first place!
With regards to HBA, how would I remove the yellow warning triangle?
Many Thanks
DJAlix
Site Sponsor
Gold Supporter
Many Thanks
Interesting. Fuse’s 34 and 4 have nothing to do with your HBA so all is ok there, and yes switch and perma live connections.
To me is seems like you have a physical issue with your HBA as the control module 20 cannot be taked to according to your scan.
pns2007
Moonstone Grey
In the fitting instructions there were 3 templates each with 3 fitting positions. If the camera were to impinge on the HBA would that through an error.
DJAlix
Site Sponsor
Gold Supporter
Don’t believe so but cannot be sure as I have never tested blocking the HBA camera before. You could try in-mounting the UTR for testing and see if the error goes away. This would not explain why the control module cannot be see however. What headlights does your vehicle have?
pns2007
Moonstone Grey
I'm a bit perplexed lol. Yesterday when I reconnected battery to move the car the HBA errors weren't there. I disconnected battery this morning and when reconnected they were there. I can't even check coding as I can't read the module
pns2007
Moonstone Grey
To add even more fuel to the fire, I flattened the battery, so it's on a trickle charger now over night!
DJAlix
Site Sponsor
Gold Supporter
Is power for your reversing camera being taken direct from the fuse box or did you use an add-in / tap? If an “add-in” which dude did you tap?
pns2007
Moonstone Grey
I inserted a wire into the fuse 19 position (the actual reverse camera fuse) which was vacant in my car
DJAlix
Site Sponsor
Gold Supporter
So nothing seems to have been disturbed there then, however there could always been a blown fuse that connects the HBA. I would start by looking at the wiring in the trim above your mirror in order to check that it was not disturbed while installing your camera.
pns2007
Moonstone Grey
I’m a stupid stupid stupid boy!!! Each positive lead from the UTR camera splits into two fly leads. You remove the pin from the fuse board and then insert one of the fly leads into that position on the fuse board and then insert the original wire into a connect like the picture attached (if that makes sense). I inserted into the wrong side of the connector so effectively breaking the circuit. Well it was late lol. Anyway no harm done!
DJAlix
Site Sponsor
Gold Supporter
I knew it had to be a physical thing. Glad you got it sorted :)
