Help Diagnosing a B5 Tdi Turbo issue with
Kelvin Williams Aug 10, 2016
  1. Kelvin Williams
    Kelvin Williams New Member
    I have no boost and it makes a funny noise when driven ( hear vid ) , no noise on tick over , and it gets louder with more load .
    I have checked the rubber pipes and cant find a leak , the compressor spindle looks ok.
    I'm looking for the cheapest way to repair this if there is one !
  2. Avatar
    Google AdSense Advertisement
  3. Kelvin Williams
    PS let me know if you can see the video as its saying i need more posts to share links ?
  4. Bradderz_1988
    4,006
    267
    Check to see if the compressor wheel is actually moving when the engine is running also did you check for any play in the shaft ??
    Sounds like a major boost leak or the turbo shaft has snapped and sheered a comp wheel. Check the EGR circuit to see if theres any exhaust gases leaking, but it does sound more compressor side of things from that video.
  5. Kelvin Williams
    The compressor is spinning away nicely when on idle , it does look like it might be hitting the side though ,
    I can feel a bit of play in the shaft , but i have no reference as to what is normal , it feels like im moving it less than a mm .
    When driving literally 0% boost though , like i was driving without the turbo actuator connected.
    I think i will just do a proper job and get the whole system out , probably could do with a few new pipes ...
  6. adamss24
    adamss24 Well-Known Member
    4,584
    412
    Check for play in And out, it does sounds like it's on last legs... Beware That Diesel engines can run on own oil so- when shaft breaks- you won't be able to stop the engine unless you stall it In gear ! It's a good time to upgrade the turbo to a gt1749va or a bv43 turbo if you decide that 110 Bhp is not enough !
  7. Kelvin Williams
    What do you mean by check play in and out ? check the compressor side?
    It dosent feel loose , its an oil pressured bearing isnt it , so when the engine is of there will be a a tiny bit of play in the shaft wont there?
    Yea one of those turbos and a re-map would be tasty , however im poor :( , i might have to go n/a........
  8. Broken Byzan
    Broken Byzan Photographic Moderator Staff Member Moderator VCDS Map User Audi A4 quattro
    13,246
    468
    that turbo is broken.
  9. Kelvin Williams
    So definitely nothing to do with the pipes ?
  10. Fire26662
    Fire26662 New Member
    13
    Sounds like something is touching the housing. If you can see marks in the compressor housing it's a fair bet the bearings have had it.
  11. aragorn
    18,728
    897
    You can see the edges of the compressor wheel are mashed and the inner bore of the housing is all marked from where its been rubbing.
  12. Avatar
  13. Kelvin Williams
    Yea it is quite sharp , i cut my finger on the blades .
    I took off all the pipes and it still makes the noise so it cant be any leaks .
    I am going to head down to " All Audi" in Bristol to see if they have any nice turbos in
  14. Kelvin Williams
    Seems like there is very little play , i have taken of the flexy pipe and the other side feels as tight , it does move slightly though.
  15. Kelvin Williams
    New used turbo and there is boost where that was no boost before.
    S4_dan and matt66604 like this.
  16. jbh
    jbh TDi lover
    1,421
    170
    if its any use to you I just took the standard turbo off my car yesterday as going to fit a gt1749va to my car.
  17. Andyb5tdi
    Andyb5tdi B5 1.9TDi AFN saloon TDi Audi A4 quattro S-line owners group
    312
    86
    Just out of interest what power is a gt1749va good for? Is it the standard TDI 130 turbo?
  18. Kelvin Williams
    Do you still have this by any chance ?
  19. Kelvin Williams
    Yea it was the standard turbo , it's gone again ....
    It has 110 bhp apparently but it has enough torque to get you about
    Andyb5tdi likes this.
