OllieH
Right, had a previous thread on here about this and was just gonna update it, but can't find it when searching. Anyway, originally I had a coilpack issue, with the engine misfiring when trying to accelerate. Replaced the coilpack and the plugs which sorted the coilpack problem, but then noticed a boost problem that wasn't there before. My S3 has a custom code stage 1 remap and when I used to accelerate I could hear the sucky/whistle noise of the turbo boosting up and the car used to accelerate hard from 2.5k revs. Now though, I can still hear the turbo boosting up at the same revs, but the car does not accelerate until 3+k revs, at which point it suddenly kicks it. The boost is definately there as if I go to change gear at say just short of 3k revs I get the normal DV noise where it is dumping the boost.
Trying to trace this problem I have done the following:
change the split-r DV for a 007P.
checked the pcv system for leaks, found a split hose and replaced it, but have since removed the pcv system altogether.
removed the front bumper and lights and traced each boost hose looking for leaks, and found nothing.
Cleaned the MAF sensor.
Not sure what to do now?? Could it be a MAF problem? At £60 ish I don't want to change it just for the sake of it.
I've got VAGCOM now so will try and log the engine later today. From reading a similar thread I'm gonna log the following:
Log 1:- 020 Timing pull, 031 Fuelling, 115 Boost.
Log 2:- 115 Boost, 002 Airflow, 031 fuelling.
Anything else I should log?
Just to add, I only changed the coilpacks for cylinders 3 and 4, so 1 and 2 are still old, but don't think my symptoms suggest coilpacks, plus when I last checked there were no faults on VAGCOM to suggest that.
Any help will be greatly appreciated with this as I'm starting to clutch at straws now, and just want it fixed.
