Davsinq
Hi there all,
the story first, took the car for a long drive, oil sensor is faulty and was asking to check the oil level. Heard a rattle in the engine bay and took the car to a garage. They diagnosed it to being a blown head gasket, plumes of white smoke pouring from the exhausts but limped home. Got a pressure test on the coolant and got told it was the turbo and cat. Took the turbo off to find the exhaust turbine was broken at the shaft and pumping oil in to the exhaust.
Got a replacement turbo but it was a K03s and not the original k03 new CAT and front lambda sensor. All fitted and running fine, until I went for a run.....
Car was pulling well but the waste gate was chirping away, parked up let it idle, turned it off. Went to go out and the car won't idle, no management light on but shows 2fault codes, P0011 and P0340 both associated with the camshaft position sensor. Car starts revs, idles at 900rpm and dies within 5 seconds.
would a remap sort this or should I get a new camshaft sensor.
Any help is greatly appreciated, car is a Audi A4 1.8t Quattro 163bhp with a BFB engine code on a 52plate.
