AudiTurbo8
- Joined
- Jan 15, 2016
- Messages
- 25
- Reaction score
- 0
- Points
- 1
Hi guys,
I have a 1.8TFSI 61 plate A3 with 60k miles. it's got FASH and has a stage 1 Revo remap. for a while it's had a problem where until it reaches 90deg, it'll hesitate at 1600rpm in every gear, and it'll carry on very faintly for the first few minutes even at that temperature. I've had it plugged into VCDS and it didn't show any faults, and there was nothing immediately obvious when data logging. One thing that was a little concerning was that the ignition timing was quite erratic at idle within about a 10deg range, but I wasn't sure if this was normal or not...?
So far I've changed fuel filter, spark plugs (made no difference), injectors (seemed to make a slight improvement), coil packs (seemed to make a slight improvement), recirc valve on the turbo, had a carbon clean done and then also manually cleaned intake valves. I'm now wondering if it could be the camshaft sensor? really running out of ideas for what this could be, so any advice would be greatly appreciated! I'm doing all the work myself so it's only the cost of parts (hence why I'm throwing parts at it instead of going to a specialist).
Thanks in advance,
Jamie
Thanks in advance,
Jamie
