hello lads wheel advice needed
AARON77
hi guys ive found some wheels that are super different and want to buy them the problem is the stud diameter is 120 and i know ours are 100 do i have any options in getting these wheels to fit onto my car
thanx
Dane
Had an 8L S3, a B5 RS4 now I have a B8 S4
You can get adapters, do you know the offset and width? Because that'll a big part
AARON77
escuse my ignorance dane is the offset the rim width ?????
if so its 8j ???
dunno if that makes any sense ????
all the wheels ive had in the past have allways been able to bolt str8 on
AARON77
No worries dude 8j is the width of the rim the offset will be ET followed by a number, eg ET 35
Standard 17 inch avus' are 7.5 inches wide and ET32 for reference.
ET57
jojo
Looking for Boost!
Staff member
Moderator
ET57 allows plenty of room for adjustment, you need to aim for ET35 for the nominal offset. A set of 20mm hub adaptors will make your wheels ET37. The lower the offset, the more your wheels goes outwards.
