Heated wing mirror fault - one side
smccran
Hi all,
My passenger side mirror has stopped heating up. Just that one, not the driver side. Thought I'd have a look at it, seeing as Audi dealer wants £120 to investigate.
This thread seems pretty good on int. Is there a report somewhere in the software in-car that might tell me what the issue is? After reading up this seems to be either a wiring issue or a glass issue.
Any advice would be appreciated.
Shaun
smog c6
More than likely the mirror heater element has degraded.
Second would be the contacts to the mirror heater have corroded.
I changed both driver and passenger sides at around 3 years old. The mirror and heater circuits seemed pretty cheap/flimsy compared to Audis of old.
If you have a multimeter you can check the resistance across the mirror heater to determine if it’s degraded.
If it’s normal you can check the voltage to the mirror heater supply.
Booboo
Hope you don't have the auto dimming mirrors. I was quoted over £300 for a glass
