  2. Dismiss Notice
Headlight switch wanted
gareth_oau Mar 18, 2010
  1. gareth_oau
    gareth_oau Member
    229
    10
    Hi all,
    I need a dashboard switch for my headlights.
    the current one is turning on my foglights when main beam is on, and thats illegal here.
    casn anyone point me somewhere where these might be for sale in the UK?
    Mine a 2000 model
  2. Avatar
    snack-media
    Advertisement
  3. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    The dashboard switches are apparantly currently on back order from the factory. Last time I checked you cannot order them.
  4. rossbrownlee
    rossbrownlee Ross_S4
    719
    take it you have already tried your local scrappies?
  5. jcs356
    jcs356 Brum brum
    2,741
    81
    This is a common fault. Try removing the switch from the dash, unplugging it, giving it a good shake, and then plugging the whole lot back in again. What happened to mine was one of the plastic mounting lugs snapped and got stuck in the switch mechanism, so when you twisted the lights on it also pulled the switch out ever so slightly, causing the front fogs to come on.
  6. gareth_oau
    gareth_oau Member
    229
    10
    thanks for the suggestions, might try the remove and jiggle!
    the S3 is quite rare here, only around 10 onthe road, so wreckies mostly havent even heard of them
