Headlight conversion mk6
strizzle Apr 4, 2017
  1. strizzle
    strizzle Active Member
    107
    44
    Hi I need some advice on a mk6 gtd I am doing a headlight conversion from basic halogen to bi xenons with the drls and I am wondering if I just need to buy the adaptors and they will work or do I need to buy modules for the auto levelling and afs to work and help would be much appreciated cheers
  2. Avatar
    Google AdSense Advertisement
  3. Darren92
    Darren92 Well-Known Member
    2,413
    627
    Before you even start thinking about that, do you have VCDS and factory wiring diagrams?
    strizzle likes this.
  4. strizzle
    107
    44
    Nope don't have vcds or a diagram I thought I would just need this http://m.ebay.co.uk/itm/291545285716 but I have read that for Auto levelling and afs it is abit more complicated and I need some more wiring looms and modules
  5. Darren92
    2,413
    627
    lol I'm afraid it just isn't as simple as putting in an adapter loom.
    If you're our of your depth then consider asking someone who retrofits for a living to undertake the job as the job you're wanting to do is complicated.
  6. xJay1337
    xJay1337 New Member
    22
    22
    You can retrofit Xenons using simply the 10-12 pin adaptor.
    If you want the shutter to work you need to run a wire to the CCM, not a hard job really and lots of info on line :)
    VCDS is required for Xenon coding to stop flickering :)
