Head Gasket Symptoms?
Pete20vt
Supermoto Junkie
I have a very light misting of custard on the oil cap, some small dark specs in the header tank (no custard) and my coolant temp gauge was like a yoyo today. Am i looking at the start of head gasket failure?
s3dave
TFSI Hybrid
Supporter
You need to get a sniff test done, in the coolant bottle, most MOT stations will do this for you for a nominal fee
ptr
I've got mayo in the filler cap, thought it was normal this time of year as I only really do short journeys, so car never warms up completely. Nothing in the header tank and no major temp issues though, I would get it checked mate.
Pete20vt
Supermoto Junkie
Yeah i figured a bit of mayo was normal from the winter but the temp gauge threw me today, fingers crossed, will get it looked at.
Badger 5 Edition...Its all about the flow...
Staff member
Moderator
If your temp gauge is up and down a bit then it could be the coolant temp sensor on its way out... have a word with Bill about getting it scanned for faults mate...
Pete20vt
Supermoto Junkie
Cheers dude, I did just text Bill actually so hoping he will have a quick look. :)
s3gazz
mine i same mate only when the car is cold it has a little mist of cream when warm it goes got told its just in a morning thing lol
Pete20vt
Supermoto Junkie
Ok so back in January i fitted a new genuine Audi thermostat which solved the problem instantly. But its now come back this week! My temp needle stays cool for ages then suddenly goes to temp. Could the new thermostat be shot already? Or could it now be the coolant temp sensor?
Endacy
I fitted a new genuine thermostat because my temperature was staying low only randomly getting to 90 and stayng there for a couple of minutes but mainly really low. It solved it but a year later it did it again, exactly the same symptoms, staying around 70 and every now and then getting up to 90. So I changed the thermostat thinking it was broken already. And it was the sender!!
Oddly the symptoms of the thermostat and temperature sender were exactly the same, understandably that threw me off a bit.
Thermostat change - 1 hour
Temperature sender - 5 minutes, because I couldn't pull the connector off.
Pete20vt
Supermoto Junkie
Cool, where's the sender on the engine, i'll change it.
Pete20vt
Supermoto Junkie
Is it the green temp sensor held in a water hose with a plastic clip?
Endacy
Yup the green one, passenger side with plastic clip. Pull clip, pull sensor, remove electric plug, fit new sensor in reverse order. New clip is a few pence, prob worth getting although it wasn't in any way tight in mine and came out fine.
Coolant doesn't come out when you do this so take out the sensor then remove the plug, took me a few minutes of failing to pull the connector with it in situ to try this.
Sensor is exepnsive, like £25 genuine but i've heard generic ones can just cause the same problems.
Pete20vt
Supermoto Junkie
Thanks, have changed these before so will do that.
worth scanning the engine and instruments for their respective temp readings.
CTS is likely playiing silly buggers
Cheers Bill, will swap the sensor and see what happens. If i still have problems i'll have to come see you.
