  2. Dismiss Notice
  1. Simon91
    Simon91 Member
    49
    13
    Are there any guides for the following? I've trawled and not found anything
    1 - Replacing grill with "RS" Grill
    2- Replacing gear knob with quattro one (side note, they're ******* expensive since I last looked in 2016)
    3- What size 18's can I replace the wheels with?
    Also if anyone has links to the correct sized rings in black/carbon on eBay for the front/back that'd be most appreciated!
  2. Avatar
    snack-media
    Advertisement
  3. Luke radcliffe
    Luke radcliffe New Member
    10
    Hi Simon,
    There is a guide for the RS grille change on an A1 forum, however mine's just being changed in a garage during having it wrapped as it is a bumper off jobby!
    Secondly I believe Audi have a specialist key fo attach/remove the gear knob specifically so if you bought one, you'd have to take it to them...
    Luke
  4. lfcrule1972
    lfcrule1972 Winter is coming... Team Mythos TFSI Owners Group Audi S1 quattro
    581
    229
    43
    You don't need the key to remove the old gear knob - I removed mine with pliers and then used them again to close the clip back onto the gear stick.
  5. SPIKE_S3
    SPIKE_S3 Vorsprung durch Technik Team Ara Blue Team Daytona
    2,017
    2,144
    Is the RS style grill now available for the FL A1/S1? I know it was only the PFL previously.
  6. lfcrule1972
    581
    229
    43
    Yep there is facelift version available now :)
  7. N@deeem
    N@deeem Member Team Sepang Audi S1
    98
    27
    The clip is a right pain unless you have the right pliers. I used a strong cable tie in place of the clip as I had normal pliers that damaged the clip during removal.
