just don't understand the abbreviations .. and without pictures i could read anything and be confused .. its just how I am (IE .. not a learn by reading person)I suggest you spend a little time reading up on the various systems you're trying to change. If you don't understand it, don't mess with it.
I did wonder about that today as noticed my oil leak was predominantly from oil feed pipe area to turbo .. and have noticed a whistling now when turbo spools up fastOil getting into the intercooler is normally from bad turbo seals
IE/etc are effectively just an expensive restriction. Stick to bigger hoses if possible.
Do you really need a 2l can?
13mm ID = 530mm^2 flow area
19mm ID (stock)= 1134mm^2 flow area.
By dropping the hose size to 13mm you're reducing the flow area to less than half which is one hell of a difference, particularly when you are putting the system under more strain from a more highly strung setup too.
Small cans are easy to hide away, they just need emptying more regularly. How much fluid are you collecting at present? Do you have to empty the existing can often? If it's very frequent or there's a lot being caught, there could be more of an underlying issue at hand.
Do i need to add an extra 1 way valve on the brake booster side? Or just conect the pipe to manifold?
I know some people added a valve to try and keep negative pressure in the block and also I am unsure about my puck being straight in the TIP. but my engine puffs out of both the breathers and has done for about a year now (3000 miles) I don't think this was caused by the catch can and was probably from 7000 rpm and a crap ECU from eBay which was maybe knocking? - everytime I put my foot down I visualise Ian's rods
guys i asked my girlfriend and she says 3bar is better "because 4bar is too big a pressure"
