  2. Dismiss Notice
Guidance needed for machine polishing...
RossN14 Apr 18, 2019
  1. RossN14
    RossN14 Registered User
    88
    81
    So after doing some research, tips from forum members and YouTube videos I think I’ve finally settled on what products I may need but if someone could confirm? I’m planning on purchasing the following products,
    DAS 6 Pro DA polisher
    Chemical Guys Hex Logic Orange Medium Cutting Pad (5.5 inch) to apply the scholl polish
    Scholl S20 Black or Scholl S30+
    Chemical Guys Hex Logic Black Finishing Pad (5.5 inch) to apply a sealant I’ve already bought
    Will the 5.5 inch Chemical Guys pads fit on the 5 inch backing plate which is supplied with the polisher?
    Is the Orange Medium Cutting Pad the right Pad for the scholl products?
    The new car is Navarra Blue and noticed some very minor swirls when I picked the car up so I want to get on top of things straight away. My usual clean is rinse, snow foam (let sit for 2-3 mins), rinse, two bucket wash with car shampoo, rinse, wash wheels and rinse. I’d then usually dry the car and apply a spray wax.
    I’ve got some clay bar, iron and fallout remover and tar and glue remover which I’d obviously use to decontaminate the bodywork before polishing. Are the products previously mentioned adequate to remove light swirl marks and then apply some protection. I’m thinking of trying it on my mums Mythos Black TT beforehand as it’s a smaller car and also 2 years older so may have better results?
    Any help appreciated
    Ross
  2. Avatar
    snack-media
    Advertisement
  3. Scotty75
    Scotty75 Well-Known Member Silver Supporter
    1,499
    2,260
    If it's only minor swirl marks I'd go with Hex Logic Green pads , the S20 should be just fine . The orange pads are for heavier defects / polishing. Have you brought some good quality micro fibre cloths ? 600 GSM or similar should be good for buffing off the polish .
    May also want to get some IPA Panel wipe to clean the panels off before applying sealant / wax
    Sent from my Nokia 8 using Tapatalk
    RossN14 likes this.
  4. jassyo06
    jassyo06 T-Cut King !
    19,711
    40,351
    3 Green Hex Logic pads = full car correction you'll need 3 pads best divide the pads by the amount panels, reason pads will last longer less you'll knacker them, clean pads with a brush after every pass
    I recommend = Sonax perfect finish use over the full car
    Menzerna 3800 = maintenance polishing whenever you fancy it
    NevMan, RossN14, T-800 and 1 other person like this.
  5. RossN14
    88
    81
    Cheers @Scotty75 and @jassyo06. So best to go with the green pads. Will the 5.5 Pad fit the 5 inch backing plate? And will 250ml be enough to polish the whole car? I’ve got some decent microfibres which I used today to just apply a spray wax and was really impressed by them.
    Washing the car today and noticed someone has dinked my front passenger door below the wing mirror. Looks like someone’s hit it with their door, not that noticeable but it is deep. It’s about 3mm. Hopefully by polishing it might mask it a little
  6. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator
    10,940
    16,179
  7. Scotty75
    1,499
    2,260
    The green pads for definite and you should be fine with 250ml of polish . You'll have some left over if anything.
    Not so sure about that 3mm scratch though . See how it looks post polish. If it's still really bad do a search for "Doctor Coloyrchip" planning on using it myself soon
    RossN14 likes this.
  8. RossN14
    88
    81
    @jassyo06 this is the thread recommended previously to which a based most of my stuff off of. Amazing the amount of info and detail that the guy goes into to explain everything.
    @Bristle Hound I now know what pads go with what backing plates after giving it another read so thank you. Hopefully get started in the next couple weeks and get some results posted on here
    NevMan and Bristle Hound like this.
  9. Scotty75
    1,499
    2,260
    Knows his stuff
    RossN14 likes this.
  10. RossN14
    88
    81
    I’ll keep that in mind cheers @Scotty75. Most probably wouldn’t notice but after washing today and now knowing it’s there is going to bug me Just hate the fact that I’m worried about parking anywhere if this might happen again, and could be worse. Never used to but now find myself parking far away in a corner whenever I need to go out anywhere
    Scotty75 likes this.
  11. RossN14
    88
    81
    Benefits of being on the forum! Always prefer finding other people’s experience and getting recommendations than just diving in without any homework haha
  12. Avatar
    snack-media
    Advertisement
  13. Scotty75
    1,499
    2,260
    Can totally relate to this. Recently had a new wing and bumper because some Tard backed into my A3 and simply buggered off.
    Stick around mate , lots of knowledge from may people here at the forum. I've learned loads and no doubt you will also .
    Looking forward to the photos of your results
    RossN14 likes this.
  14. jassyo06
    19,711
    40,351
    250 ml is plenty to do the whole car, green pads defo on new paint, backing plate surface size is always smaller than the surface of the pad, ie Hex Logic Quantum pads are slightly cone shaped, remember it's the quantum Hex Logic pads you need as they have less wobble on the DA = more control easier to handle
    RossN14 and Scotty75 like this.
  15. RossN14
    88
    81
    Just ordered the DAS 6 Pro, sonax perfect finish, Menzerna 3800, Black hex pad and green hex pads. Also got a bottle of IPA coming to wipe down afterwards. Helpfully going to get round to giving the car a good polish in the next couple weeks. Probably after my exams. Thanks again for all the help guys and I’ll post pics once it’s done
  16. RossN14
    88
    81
    So managed to get the car polished and applied a sealant before the rain started. Really pleased with the results
    Bristle Hound, A4A4, NevMan and 3 others like this.
  17. jassyo06
    19,711
    40,351
    NevMan, T-800 and RossN14 like this.
  18. RossN14
    88
    81
    @jassyo06 used the sonax perfect finish along with the green hex pads. Amazed at how easy it was to get some really good results. Already offered to do my mums TT and my friends S1. Think I’ll be polishing someone’s car every weekend for the foreseeable future. Thanks again for all the advice
    NevMan, Scotty75 and jassyo06 like this.
  19. jassyo06
    19,711
    40,351
    Lol...it's addictive aint it...hard graft though.........plus the fact the more time you spend with with the machine and compounds.........the better the results you'll achieve mate...........as l have always said machine polishing aint rocket science.....finding the right products is half the battle....the rest is down to sheer determination
    NevMan, Scotty75, T-800 and 1 other person like this.
  20. Scotty75
    1,499
    2,260
    Wise words
    jassyo06, RossN14 and NevMan like this.
  21. NevMan
    NevMan Well known member
    6,732
    8,824
    jassyo06 and RossN14 like this.
  22. S3KEY
    S3KEY Registered User
    74
    37
    Very nice finish mate, how many passes did you need to do to correct swirl marks? My panther black (as you can imagine being black) is covered in swirls and also was it easy to use the polisher? I just havnt grown the b*****ks to get my das pro out the bag yet haha
    RossN14 likes this.
  23. RossN14
    88
    81
    I was really apprehensive about doing it too but honestly just go for it, really easy. On most panels I just did 3-4 passes and found that was enough. I had a light scratch on my drivers door so went over that two times more at a higher speed.
    Think it’s better to maintain and sort these things early on, rather than let them get bad and have to use products which will take more cut. And make sure you add some protection once you’re done, whether it be wax, sealant, etc, after all that work. It probably took me about 2-3 hours just to polish and then apply a sealant. Maybe another 2 hours to prep the car as I had washed, decontaminated, washed again, clay barred and then dried the car to make sure I wasn’t dragging an **** across the bodywork.
    Scotty75, NevMan and A4A4 like this.
  24. S3KEY
    74
    37
    Amazing!! Thank you brother think I’m going to do it this weekend if the weathers nice, don’t have a garage (yet) at the new house so has to be a driveway job, not that bad though as My drive has my house on one side and a 6ft wall on the other and fencing blocking the back so fairly blocked from wind etc, I’ll do my usual prep work and wash then I’ll wipe each panel down before I go anywhere near it with the da. Thanks for the reply I’ll get some pics up of before and after hopefully all goes well, eeeek!!
    Scotty75 and NevMan like this.
  25. RossN14
    88
    81
    Good luck with it and looking forward to seeing the results. I done it in the drive too as our garage isn’t big enough. Think the panther will look really special after it
    NevMan and S3KEY like this.
  26. Scotty75
    1,499
    2,260
    Definitely be worth using a clay bar on the car, particularly if it's going to be it's first machine polish . Bilt Hamber Clay bar is a tenner , money well spent and better finish in the end .
    NevMan likes this.
  27. S3KEY
    74
    37
    Cheers buddy, ill do a full decontamination I always do, will be snowfoam, iron/fallout remover, 2bucket wash, Clay bar, then ipa wipedown as I go along! Agreed though clay bar is a 100% must have!
  28. Scotty75
    1,499
    2,260
    It's really surprising even after doing decon how many contaminants the clay picks up. Big fan of clay bar nowadays
  29. S3KEY
    74
    37
    Think the trick is to get a decent clay bar, ive not tried Bilt Hamber clay but I’m going to buy that next time ive used the meguiars clay bar which I though was very good and the autoglym Clay bar I preferred the megs one, afew friends have bought some cheapos from eBay and had mixed results hence why I have just bought the “branded” stuff don’t fancy buying a cheap clay bar and it grinding s**t down my paintwork!
  30. NevMan
    6,732
    8,824
    Used a BH clay bar on my son’s corsa. Had tree sap all over it (came from Vauxhall’s like this!) that NOTHING would properly shift:
    Scotty75 and S3KEY like this.
  31. S3KEY
    74
    37
    Nice job!! And thanks for another recommendation on the BH clay bar I’ve just ordered myself one (or 2) haha don’t tell the misses
  32. Scotty75
    1,499
    2,260
    @jassyo06 gave me a very good tip for claying the car . Get an empty spray bottle and dilute a very small amount of fairy liquid with tap water . Use the spray as lubricant while your claying . Works a treat and also helps remove previous coatings while you're at it.
    I know some here frown upon FL but it really did work well for me and excellent as clay lube
    S3KEY likes this.
  33. Avatar
    snack-media
    Advertisement
  34. S3KEY
    74
    37
    Thanks mate, and yes very good tip too I’ve also been recommended this by afew people over on detailing world but a lot of backlash from it too but each to there own I say!
