  1. CroftyOriginal
    CroftyOriginal Member
    60
    Okay so, if you have seen my latest post you'll know my oil pressure light came on after a 4th gear pull on the dyno, changed the pressure switch, went back to the dyno again a week later after having no issues on the road, and the oil pressure light came back on while on the dyno doing the 4th gear pull. So I thought it may be a buggered oil pump/balance shaft but thought I would change the oil and filter just to check, the light has now gone out but still not trusting it as I found grit in the oil, quite a bit too, tried picking it up with a magnet and nothing stuck to it. Then did an oil pressure test and got about 35psi on a warm, not hot start. (Pictures below)
  2. Avatar
    Google AdSense Advertisement
  3. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 S tronic
    16,572
    2,368
    Is it plastic or (hopefully) just old oil
  4. CroftyOriginal
    60
    It felt more like soft sand, if that makes any sense. Apparently the garage changed it a month ago... Starting to think they didnt.....
