  2. Dismiss Notice
GPS & ACC BREAKING NOT AVAILABLE
ch33p0x Oct 23, 2018
  1. ch33p0x
    ch33p0x Registered User
    Hi! I’ve recently had some problems with my ACC. (Adaptive Cruise Control) I get this info in my dash «ACC breaking guard not available»
    I’ve been to an Audi dealership.
    Because of ACC not working, is because of the GPS. The GPS antenna (fin) is defect. That’s why i get that message in my dash all the time.
    I have to replace the fin, and that will solve the problem. But i’ve been googling a little bit. Is there something else that have to be replaced? Inside the car? Or will the fin be just fine? I think its wierd that the broken gps on the roof takes out the ACC?
    But i know that the navigation system is connected to the ACC? So maybe not so wierd?
    It’s an Audi A6 avant (4g/c7) 2012 (3.0TDI)
    Maybe a different thread, but:
    I also got a error message from diagnose with the fuel lid. «Short to ground» or something... how to fix that as well? I don’t have a lid i open from the inside of the car, i just push/press the lid to open. So i dont understand why the «short to ground» is coming
    Thanks for any reply
  2. Avatar
    snack-media
    Advertisement
  3. RAF_S7
    RAF_S7 Well-Known Member Gold Supporter
    1,989
    1,083
    There is no connection between ACC and GPS that I’m aware of.
    There is a connection between GPS and auto headlights for cornering - and auto selection of beam shape for driving on the left (UK) or right (Europe) roads.
    ACC can become unavailable for a number of reasons, and because it’s a critical driver assist package, it’s taken offline and can only be reset by the dealer, or VCDS.
    Things that can cause the ACC to go offline include:
    Fault on the self levelling suspension (too high or too low)
    Fault on one of the two Radar pods on the lower front bumper.
    Bumper been removed and radar pods disturbed, so out of alignment (realignment is a dealer only job)
    Fault on the forward facing camera (in front of interior mirror)
    You really need a VCDS scan to pinpoint what has failed. I would scan, save the results, then clear any faultcodes and see if the issue returns.
    The fault code regarding the fuel lid is a common problem on the older cars. When you lock the car, the fuel lid is also locked. The fault code is indicating a problem with the solenoid that locks the fuel lid. When it fails, it fails in the locked position meaning you won’t be able to open and fill with fuel (There is an emergence release cable inside the car, behind the right hand cubby which you need to remove to get to - see your manual for exact location)
    The failed solenoid can’t be repaired, it’s a complete replacement. It’s usually an intermittent failure, followed by complete failure.
  4. RJ-8V
    RJ-8V Registered User
    749
    187
    43
    On the A6/7/8 ACC works also with the GPS radar. There are three components for ACC: radars, camera om windshield and antenna in roof.
    It's a sophisticated system on the A6.
    Also a common Fault that ACC and Braking Guard are not available. Most of the time its the antenna.
    Note: almost all the Audi's models from end 2011 Till Early 2013 have antenna problems because of the rubbers around the antenna are faulty. Water gets in.
    Just scan it with vcds, look at the errors. And replace the original antenna on the roof. Its not cheap.
    A3 8V Facelift Limousine
  5. DaveW
    DaveW Registered User
    1,463
    674
    I can vouch for the water antenna damage, I had a 2012 C7 which started to plot me right in the middle if the River Mersey following a particularly heavy downpour.
  6. Mo-S3
    Mo-S3 Registered User
    868
    37
    Common fault on the 4G model. If you dont want to pull the headlining down and change the antenna then get hold of a surface mount gps antenna that has a blue fakra connector. Pull the mmi unit out and plug it into the blue connector where the original one fits.
    The same roof antenna is also used for mobile signal so make sure that is working fine if not then you will need to change the roof one
  7. Tendaimwari
    Tendaimwari Registered User
    166
    Thread resurrection.
    Mine has developed the same problem. I've swapped out the antenna for one of those puck types. Satnav works perfectly and it worked fine for the first day. Now it starts ot ping after approx 5-10 miles into a journey. In comparison, the shark fin antenna sets off the warning before driving off.
    Anyone have any ideas? I'll do a scan later and post the results.
  8. Tendaimwari
    166
    Here is the scan results. The antenna fault code for the new puck antenna is the same as the one for the shark fin. The only difference is the shark fin triggers the ACC unavailable from the get go. The puck antenna takes longer.
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3B 3C 42 44 46 52 53 55
    56 5F 62 72 85 8B 8E 8F 90
    VIN: WAUZZZ4G5DN007153 Mileage: 115058km-71493miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8E-Image Processing -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    Address 01: Engine (J623-CDUD) Labels:. 059-907-401-V2.clb
    Part No SW: 4G0 907 401 Q HW: 4G0 907 401
    Component: 3.0TDI EDC17 H37 0002
    Revision: 53H37---
    Coding: 12254012056601020000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
    ROD: EV_ECM30TDI0114G0907401Q.rod
    VCID: 313C1F2421A5611F213-8064
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 4G1 927 156 T HW: 0B5 927 156 J
    Component: 0B5 30 TDIRdW H01 0003
    Revision: --H01--- Serial number: 0000000713
    Coding: 000001
    ASAM Dataset: EV_TCMDL501021 001009
    ROD: EV_TCMDL501021.rod
    VCID: 3E263418E0FB8E67AC1-806A
    1 Fault Found:
    7980 - RPM Signal from ECU
    P0726 00 [046] - Implausible Signal
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 37
    Reset counter: 40
    Mileage: 114716 km
    Date: 2019.01.14
    Time: 06:51:42
    Engine speed: 1547 /min
    Transmission input speed: 1547 /min
    Transmission output speed: 495 /min
    Engine torque: 120 Nm
    Transmission fluid temperature: 52 °C
    Accelerator position: 22.8 %
    Clutch status: Kupplung 1 kann Moment übertragen
    Unlearning counter according OBD: 40
    Engine speed: 834 /min
    Transmission_rotational_speed_working_cycle-Data: 166 /min
    Transmission input speed: 834.00 /min
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
    Component: ESP PREMIUM H09 0361
    Revision: -------- Serial number: --------------
    Coding: 27A68701E465E180DB00
    ASAM Dataset: EV_ESPPremiAU57X 004028
    ROD: EV_ESPPremiAU57X_004_AU57.rod
    VCID: 382A2200C2DFB05766D-806C
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
    Component: BCM2 2.0 H32 0421
    Revision: 00002001
    Coding: 01B93046000000000000
    VCID: 77A8E13C8FC17F2FAF7-8022
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 2312000096367014
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
    Part No SW: 4G0 820 043 AC HW: 4G0 820 043 AC
    Component: KLIMA 2 ZONEN H11 0070
    Serial number: 24051200110078
    Coding: 3622000825
    ASAM Dataset: EV_AirCondiBasisUDS 002040
    ROD: EV_AirCondiBasisUDS_002.rod
    VCID: 609AAA603ACF9897FED-8034
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
    Component: BCM1 2.0 H12 0130
    Revision: 20012002 Serial number: 00000001504642
    Coding: 2600A01040349FE28181008300001D0CCF9DC70827090201000004606100
    VCID: 6E86C458F09B3EE77C1-803A
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS57X 120405 H35 0080
    Serial number: 120417003453
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 20280615
    Coding: 02006D
    Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
    Component: E1 - LDS H07 0044
    Serial number: 21 05 2012 00000780
    Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
    Component: Humidity_Sens H03 0002
    Serial number: 18688A26000000000001
    1 Fault Found:
    03674 - Indicator Lamp for Start-Stop Operation
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 3
    Mileage: 115021 km
    Time Indication: 0
    Date: 2019.01.21
    Time: 07:05:00
    Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
    Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
    Component: PARKHILFE ACC H01 0072
    Revision: 11001001 Serial number: 61061213301742
    Coding: 88EB08
    ASAM Dataset: EV_EPHVA18AU57X0000 003008
    ROD: EV_EPHVA18AU57X0000_003.rod
    VCID: 77A8E13C8F417F2FAF7-8022
    Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 561 A HW: 4G0 907 561
    Component: ACC3 H17 0400
    Serial number: 00000000000000
    Coding: 7E04010202
    ASAM Dataset: EV_AdaptCruisContrAU57X 002010
    ROD: EV_AdaptCruisContrAU57X_002.rod
    VCID: 280AF240127F20D7F6D-807C
    1 Fault Found:
    145408 - Function Restriction due to Faults in Other Modules
    U1113 00 [009] - -
    [FAULT_CIS_NAVI_FAIL]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 254
    Reset counter: 220
    Mileage: 114905 km
    Date: 2019.01.18
    Time: 18:44:39
    Control Module temperature: 22 °C
    Voltage terminal 15: 11.483 V
    Velocity_vehicle_reference: -0.01 m/s
    Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
    Component: Airbag10.43 H43 0040
    Revision: -------- Serial number: 003JG008MG20
    Coding: 30323436313330303539554A305234473053
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 36362C38C8CB4627741-8062
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB405R1C4LI1P1M
    Crash sensor for side airbag: front passenger side:
    Serial number: 3585HRB40671CAICBH68
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515JRB404P184COA0KB
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525JRB405F18E5EG1Q9
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB400K4UE2089IN
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB400I4UE20M1DN
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
    Component: Lenks.Modul H03 0005
    Revision: -------- Serial number: 90372LEG000K5
    Coding: 0000FD
    VCID: 3728213CCF41BF2F6F7-8062
    Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
    Component: E221 - MFL H08 0009
    Serial number: 30 03 2012 D0047994
    Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G8 920 983 J HW: 4G8 920 983 J
    Component: TDieGb Acc H79 0515
    Revision: 28460207 Serial number: 658080512596016
    Coding: 238F10000F512600010000
    ASAM Dataset: EV_RBD4K 004046
    ROD: EV_RBD4K.rod
    VCID: 3C223E10F6E79C77825-8068
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 4G0 907 468 AB HW: 4G0 907 468 AA
    Component: J533--Gateway H10 0028
    Revision: -------- Serial number: 00000000535507
    Coding: 00CD077D00
    ASAM Dataset: EV_GatewPkoUDS 001013
    ROD: EV_GatewPkoUDS_001_AU57.rod
    VCID: 70BADA20EA2F28176ED-8024
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
    Component: J367-BDM H07 0141
    Serial number: 00000000003790407372
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
    Component: J532_DCDCStab H23 0021
    Serial number: 27021200000000000355
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
    Component: SARA 6D H02 0009
    Revision: -------- Serial number: EJ1BPA42050J7V0
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA 009017
    ROD: EV_SARA_009.rod
    VCID: 2D0403543D9D05FF05B-8078
    Address 3C: Lane Change Labels: Redir Fail!
    Part No SW: 4G0 907 566 D HW: 4G0 907 566
    Component: J769 SWA MasterH01 0040
    Revision: 00H01000 Serial number: 6PZ 010 287-03
    Coding: 0001102
    VCID: 303A1A20262F68172ED-8064
    Subsystem 1 - Part No: 4G0 907 568 D
    Component: J770 SWA Slave H01 0040
    Subsystem 2 - Serial number: 6PZ 010 287-23
    Subsystem 3 - Serial number: 5F22.05.1200H010003CF24174ÿ
    Subsystem 4 - Serial number: F24174ÿ
    Address 42: Door Elect, Driver (J386) Labels: None
    Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
    Component: TSG FA H04 0506
    Coding: 011F16005C01628002080013
    VCID: 45D45BF485ADDDBFEDB-8010
    Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
    Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
    Component: RCEPS H35 0010
    Revision: 00001000 Serial number: 0027405788
    Coding: 101001010000
    ASAM Dataset: EV_RCEPS 009008
    ROD: EV_RCEPS_009.rod
    VCID: 323E102824A35A07589-8066
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0176441947
    Coding: 013B062220B90080832009042001040F0000000000000000000000000000
    Subsystem 1 - Part No: 4G0 951 177
    Component: DWA-Sensor H01 0010
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    1 Fault Found:
    01517 - Control Module for Trailer/Towing Sensor (J345)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 215
    Mileage: 114905 km
    Time Indication: 0
    Date: 2019.01.18
    Time: 18:44:59
    Address 52: Door Elect, Pass. (J387) Labels: None
    Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
    Component: TSG BF H03 0506
    Coding: 011F16005C01628002080002
    VCID: 46D65CF8B8ABD6A7E41-8012
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
    Component: EPB-4 H03 0013
    Revision: -------- Serial number: 00000000354291
    ASAM Dataset: EV_ParkiBrake 001027
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 2B000D4C03890BCF1BF-807E
    Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
    Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
    Component: ....LWR12.... H02 0013
    Serial number: 120521-0001-032
    Coding: 1122A6101000A300
    ASAM Dataset: EV_HeadlRegulBasic 005001
    ROD: EV_HeadlRegulBasic.rod
    VCID: 2C020E5006870CF7125-8078
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 056 J HW: 4G0 035 056
    Component: Radio U STD H60 0133
    Revision: AB001007 Serial number: 230E.0C7565493
    Coding: 010003020100000001
    VCID: 280AF24012FF20D7F6D-807C
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 4G0 035 670 Q HW: 4G0 035 670 H
    Component: H-BNT-EU H49 1034
    Revision: -------- Serial number: 190EY0C7504447
    Coding: 050101010003E9ED3D90CF3E00000003000001000000000000
    VCID: 313C1F242125611F213-8064
    Subsystem 1 - Part No: 8R0 060 884 ED
    Component: EUR 2017 2402
    Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
    Component: DU8 C7 SV H42 0021
    Serial number: AUZ8ZDC9401CE6H
    Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
    Component: E380 BDT C7 H11 0204
    Serial number: 90349LEM000LF
    Subsystem 4 - Part No: 8R0 060 961 C
    Component: CD-Database 3638
    2 Faults Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 5
    Reset counter: 219
    Mileage: 114905 km
    Time Indication: 0
    Date: 2019.01.18
    Time: 18:46:10
    Freeze Frame:
    Voltage: 11.80 V
    03623 - Invalid Secruity/Release Code
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 215
    Mileage: 114905 km
    Time Indication: 0
    Date: 2019.01.18
    Time: 18:46:00
    Freeze Frame:
    Hex Value: 0x0004
    Hex Value: 0x000B
    Count: 6
    Address 62: Door, Rear Left (J388) Labels: None
    Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
    Component: TSG HL H03 0506
    Coding: 010F14004001628002080002
    VCID: 49CC57C4A9B539DF093-801C
    Address 72: Door, Rear Right (J389) Labels: None
    Component: TSG HR H03 0506
    Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
    Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
    Component: DPC-SG H25 0038
    Revision: -------- Serial number: 262130025421000
    Coding: 6A060000
    ASAM Dataset: EV_OnBoardCamerDPC 001007
    ROD: EV_OnBoardCamerDPC.rod
    VCID: 2616FC78186B36A7C41-8072
    Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 541 A HW: 4G0 907 541
    Coding: 7E04010202
    ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
    ROD: EV_AdaptCruisContr2AU57X_002.rod
    1 Fault Found:
    U1113 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Reset counter: 220
    Mileage: 114743 km
    Date: 2019.01.14
    Time: 17:37:51
    Control Module temperature: 24 °C
    Voltage terminal 15: 11.421 V
    Velocity_vehicle_reference: -0.00 m/s
    Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
    Part No SW: 4G0 907 107 D HW: 4H0 907 107
    Component: BV-SG H30 0038
    Serial number: 005000052005127
    Coding: 04C238181111
    ASAM Dataset: EV_BC7 001001
    ROD: EV_BC7.rod
    VCID: 2708F17C1F612FAFFF7-8072
    Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 945 B HW: 4H0 980 945 B
    Component: RGS-VL H13 0080
    Coding: 0066E608031F037E070308004240C2010000
    ASAM Dataset: EV_RGS_L 002004
    ROD: EV_RGS_L.rod
    Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 946 B HW: 4H0 980 946 B
    Component: RGS-VR H13 0080
    ASAM Dataset: EV_RGS_R 002004
    ROD: EV_RGS_R.rod
    No fault code found
  9. RJ-8V
    749
    187
    43
    Don't use a puck antenna....buy the original one. Because ACC uses the antenna.....
  10. Tendaimwari
    166
    Thanks for the response. What are the differences between the shark fin GPS antenna and the puck type GPS antenna?
  11. RJ-8V
    749
    187
    43
    Shark antenna has an extra connector which the acc system connects to. Non-acc shark Fin has two connectors, acc version has three.
  12. Avatar
    snack-media
    Advertisement
  13. Tendaimwari
    166
    Understood. I'll be visiting my local dealership in the coming days. Do you know if it's just a "simple" case of plug and play change? No re-routing of cables etc
  14. RJ-8V
    749
    187
    43
    Plug and play
  15. Tendaimwari
    166
    After faffing around removing the roof lining.....
  16. RJ-8V
    749
    187
    43
    Ofcourse :)
  17. Slackworth
    Slackworth Registered User
    417
    82
    If you have an Avant and very flexible fingers, you don't need to remove the headliner - you can access it just about enough to undo it and replace it. You need o take off the panel between the bootlid edge and headliner though but it pulls off with a little bit of force - you can always replace the clips after but I had no need.
  18. Tendaimwari
    166
    I do have an Avant and read your removal pointers on another thread. I had to remove it this afternoon to confirm the part number. The dealership were referemcing a part number that turned out to be different to the one on the antenna. Anyway, one is on order and should be here by the weekeend. I noticed that the plastic cover is screwed to the base. Do I swap the covers or pain the new one?
    Thanks to you both for the help.:icon thumright:
  19. Slackworth
    417
    82
    I brought mine off eBay luckily in the same colour as the body to save that hassle so not sure on that one. The dealership price was slightly eyewatering compared to a 2nd hand one which was in perfect condition when it arrived :)
  20. Tendaimwari
    166
    Short update: Bought a second hand antenna from a MY2017 car but had to respray the cover because the tiny screws on the faulty fin rounded off.
Tags:
