  2. Dismiss Notice
Got VCDS and an S3? Help a brotha out...
Tom93 Apr 19, 2016
  1. Tom93
    Tom93 Active Member
    436
    79
    I think my throttle body is dead, many reasons, idles weird, over revs on gearchanges, and said 0.0% for throttle position on idle at Bills, not doing that one anymore but i still think its shot. I done a TB alignment or whatever its called then checked the position with the pedal just resting and again flat to the floor... was hoping to compare to somebody whos car works properly? Surely the percentages should atleast be similar?.. Thanks anyone who can help :)
    So accelerator pedal in rest position
    And flat to the floor...
  2. Avatar
    snack-media
    Advertisement
  3. Tomsy
    Tomsy KERNOW Team Avus Silver Team Silver Audi S3 quattro Manual
    92
    I live in Lanivet, you could look at mine?
    P.s my car used to over Rev on gear changes and I replaced the clutch switch and it cured it. ( thanks to this forum! )
  4. Tom93
    Tom93 Active Member
    436
    79
    Ive put 2 clutch switches in this, both from audi and the problem persists.
  5. Tomsy
    92
    Well if you need my TB to try then I could come over... I delivered heating oil to your house so I know where you are.
  6. dusty
    dusty Active Member Team Nogaro Blue Audi S3
    265
    46
    Just had vcds on my car to do something else so thought I would have a look my readings they are all within 1% of your above figures
  7. Tom93
    Tom93 Active Member
    436
    79
    Hmm weird, thanks above chaps. What now lol
  8. Tom93
    Tom93 Active Member
    436
    79
    So this is really ******* me off now. Seems to be everytime im in the high rpms going from 3rd to 4th, 4th to 5th and 5th to 6th the revs jump up. Anyone got any ideas? I have checked in vcds and can see the clutch switch working. Had a smoke test at badger5 and i was air tight. Its definately not me being a twat as ive paid special attention to make sure im off the throttle before dipping the clutch and it still does it. Its driving my mental.
  9. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    3,203
    919
    Mines being doing this for ages if I'm high revs and take foot of pedal it jumps even if I don't press clucth at all, does drive you mad
  10. Gops
    Gops Badger 5 Edition Gold Supporter VCDS Map User Audi S3
    3,181
    667
    Any codes for the TB? disconnect it and reconnect it. Align it on VCDS again and check block 032.
    Taken from another thread:
    There are two fields in the block, and both belong to fuel trims.
    Left hand one is short term adaption, right hand one is long term adaption. Left hand one is the one to look at in this instance.
    Make a note of these two figures. Reset the fault codes (even if there are none), as this will clear the fuel trim data back to 0% for both blocks.
    Then start the motor and log block 032. If the value in the left hand block steadily climbs to or past the 3-4% area, it's normally a good indication of a leak.
  11. aragorn
    18,712
    902
    the percentages are supposed to be different.
    One starts from 0 and moves towards 100 as the throttle opens, the other starts from 100 and moves towards zero as the throttle opens. This allows the ECU some redundancy.
    Have you checked the clutch switch within VCDS to ensure its switching over correctly. There should be a measuring block that shows you its status.
    I fitted one recently as part of a DBW conversion, and while it looked like it was fitted and working, it wasnt far enough in and was constantly in the "clutch down" position.
