Ess_Three said:It may be fine if you 1/4 mile it and nothing more...but as a drivers car, a 350BHP+ S3 just doesn't make sense to me.
In all honesty, the big turbo cars aren't 'that' much faster point to point than a highly strung K04's car.
edward_harris said:I'm think the reason it doesn't feel that fast is because they are soooo well built!
i think a m3 would struggle to pass me on a straight!
Ess_Three said:Is that why my 911 feels fast then?
Because it's built ****?
Get a grip...an M3 or 911 feel faster...and they are just as well built.
Well bulit fast cars still feel fast.
But a standard M3 would murder an S3 on handling unless the S3 was very well sorted....so best you stick to straight lines then!
edward_harris said:My s3 is very well sorted thankyou!
You need to remember how much your 911 weights and how much £ it costs!
its a completely different car than the s3!
Also depends who's driving dont forget!
ChriS3 said:That's pretty much what I'd say. More power is a lot more fun in a straight line, but after a year of this turbo I think the quickest point to point conversion for the car would have been a hybrid K04.
Ess_Three said:When it comes to handling...your S3 is merely first stage, in my view.
You need to go much further to have an S3 that outhandles Evos and STIs...
Mine did...road and track.
So what else would you say i need to do to mine to get it like yours was running? what am i missing? do you still have your s3? what is it running?
Ryanc said:sim,a remapped k04 cannot do 0-100 in 12s.14s is about the best it can do.
edward_harris said:So what else would you say i need to do to mine to get it like yours was running? what am i missing? do you still have your s3? what is it running?
simch said:Good job it's not a remapped k04 then!
No, it definately does 0-100 speedo in just over 12, I video'd it and it was timed from the car too and that si with VAgcom showing only about 1.2bar max.
Down B and Q for some drainpipe for a CAI for the stock air box!!
Ess_Three said:Hmm...something doesn't add up.
Cainey's TT runs mid 12s with 415 BHP on NO2...and with a longer set of first few gears.
What's the spec on yours to be faster?
His is one of the fastest I've seen run...and it IS quick!
simch said:0-100 on speedo (c97 GPS) is low 12's not 1/4 mile. Thats with sidestepping at 4500 and no clutch slip, (thanks Sachs!) but lots of smell! even with ESP off they tyres only just "chirp" breifly. Its not that quick when you think about it, proabably mid to high 12's to a genuine 100mph.
0-100 speedo needs a change to 4th, so not sure the longer 1st and 2nd ratios hold mine back to 100..?
I have a Front mount so will try the 4 inch ducting. I have the neoprene wired duct on the Mk4 but that has gone a bit rusty inside wiht the water getting sucked in! Really after some Black flexi tube with plastic coated wire support in it..?
edward_harris said:I'm think the reason it doesn't feel that fast is because they are soooo well built! I did say my friends scooby feels so much quicker running 330bhp, so i raced him the other day and theres nothing in it! they are exactly the same! So when I'm running 1.7bar i dont think there will be a problem having him! + how many m3 do you see around they are everywhere! i think a m3 would struggle to pass me on a straight!
leave1 said:Yeah, you could probably take an M3 in a straight line providing you are in the powerband. But from a standing start you wouldn't have a change. The M3 would murder an S3 in corners, too.
Ess_Three said:What suspension stuff do you currently run?
I found big gains from the set up...
you have to be prepared to mess about, trying different angles, settings and tyre pressures.
Basic bolt on stuff is good...but optimising it gave much better results.
I don't still have my S3...it's on it's 3rd owner now...D J Motorsport, on here.
It was well set up, well braked and running a high boost K04 (1.8+ bar boost) making 275-280 BHP and 330+ lb-ft torque.
Jampublic said:M3 is like 4.9sec 0-60mph, its like an everyday car with supercar performance! I don't think anyone has had a S3 do 0-60 in sub 5!
