Got an issue ?
Y10 KED May 17, 2018
  1. Y10 KED
    Y10 KED Member
    59
    Hey guys so I have a issue with the car, I am unsure what it is.
    I drove it all morning and mos of the afternoon and it was fine then got in it in the evening and now have no boost. I have plugged it in and it’s saying there is low fuel pressure in the fuel rail and the car is running lean.
    Any suggestions before I go spending money on the wrong bits
  2. Avatar
    Google AdSense Advertisement
  3. maxdrz400
    maxdrz400 Active Member
    252
    95
    Cam follower worn?
  4. Ash_mtb
    Ash_mtb Active Member
    114
    51
    As above check your hpfp, the cam follower can wear through and eat ur pump and camshaft. Good luck
  5. Y10 KED
    Y10 KED Member
    59
    Can I buy a cam follower replacement kit ?
  6. Just Rob.
    Just Rob. Moderator Staff Member Moderator Team Daytona Team Brilliant Black TFSI Owners Group VCDS Map User Audi A4 Audi Avant Owner Group quattro S-line owners group Manual
    8,467
    4,541
    can be purchased as a single part from any audi , tps or other 3rd party outlets. make sure you quote your engine code , cheap as chips part and easy to fit.
  7. Ash_mtb
    114
    51
    Change the seal on the pump too. it is easy, theres a jhmotorsport guide on youtube for it which is really good if unsure
    Just Rob. likes this.
  8. Y10 KED
    Y10 KED Member
    59
    Found the issue it’s my PCV, it’s causing an air leak on the intake manifold. Just got to wait for it to turn up now :(
