  2. Dismiss Notice
Golf VR6 throttle body mod?
Oranoco Dec 30, 2016
  1. Oranoco
    Oranoco Registered User
    4,026
    417
    Been doing some reading, dangerous I know, and the consensus is the AEB's stock throttle body is a tad small. It seems from some US sites that it's feasible to use the 2.8 Golf VR6's as an upgrade.
    Has anybody done it?
  2. Avatar
    snack-media
    Advertisement
  3. EvilSnow
    EvilSnow Registered User
    596
    33
    Quote;
    offroader1006 said:
    06-27-2008 12:41 PM
    Re: AEB-VR6 Throttle body swap
    i noticed a big difference in throttle response.
    i am only on a k04 so no real power gains.
    but off idle throttle and part throttle driving are much easier now.
    and i havent found any caps big enough for a clamp to fit on.
    Sent from my SM-G920F using Tapatalk
    PaulJC84 likes this.
  4. aragorn
    18,710
    909
    i dont think theres any point changing when using standard frame turbochargers.
    Maybe if you were up over 400+hp.
  5. Samuel c5 Q
    Samuel c5 Q Registered User Silver Supporter VCDS Map User
    626
    124
    43
    Rs4 throttle can be a good mod for the 1.8t when flowing muchos muchos air. Can make 15-20 bhp difference when floating around the 350-400 bhp mark. Also the torque comes up as well. Is there an early s4 tb at 55mm then one at 60mm for the 1.8t and s4 then 65mm for a later b5 s4 and then is the rs4 b5 80mm. There is a tb 5mm up from the rs4 b5 off of a Chevrolet or something but on the 1.8t at least it idles very lumpy.
  6. Oranoco
    4,026
    417
    Most TB's seem to be DBW,mine being an AEB is a cable throttle. Sadly rules out a lot of options as I really didn't.t fancy the swap to DBW although did consider it briefly. Went down the AGU Golf ECU route.
  7. Samuel c5 Q
    626
    124
    43
    AGU is narrow band is it not?
  8. Oranoco
    4,026
    417
    Basically the same as the original ECU but it can be flashed rather than requiring a physical chip. It's not closed loop.
    I was looking at swapping to a later set up but decided against it
