_Zerocool_
Hi all.
Mrs Zero has been having some major problems with her Golf GTI recently and its now sitting outside the local garage broken.
Its misfiring really badly and stinks of fuel. Its really hard to start and white smoke is pouring out the back of it.
It wasn't this bad yesterday and wasn't smelling of fuel. As it had all the spark plugs replaced 3 weeks ago I thought it may have been a coil pack as it was only showing a misfire in cylinder 1 on VCDS.
Now its showing 6 engine faults as below.
Injectors????
Any ideas.
I hate cars!
6 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 79364 km
Time Indication: 0
Date: 2015.10.06
Time: 07:59:46
Freeze Frame:
RPM: 2588 /min
Load: 20.4 %
Speed: 106.0 km/h
Temperature: 98.0°C
Temperature: 19.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79256 km
Time Indication: 0
Date: 2015.10.03
Time: 17:54:24
Freeze Frame:
RPM: 1520 /min
Load: 21.6 %
Speed: 61.0 km/h
Temperature: 96.0°C
Temperature: 15.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79364 km
Time Indication: 0
Date: 2015.10.06
Time: 07:59:46
Freeze Frame:
RPM: 2588 /min
Load: 20.4 %
Speed: 106.0 km/h
Temperature: 98.0°C
Temperature: 19.0°C
Voltage: 14.097 V
004874 - Cylinder Disabling
P130A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 79364 km
Time Indication: 0
Date: 2015.10.06
Time: 07:59:55
Freeze Frame:
RPM: 2488 /min
Load: 30.6 %
Speed: 102.0 km/h
Temperature: 98.0°C
Temperature: 20.0°C
Voltage: 14.097 V
000135 - Fuel Rail/System Pressure
P0087 - 000 - Too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 20
Reset counter: 255
Mileage: 79365 km
Time Indication: 0
Date: 2015.10.06
Time: 08:00:23
Freeze Frame:
RPM: 2331 /min
Load: 43.1 %
Speed: 95.0 km/h
Temperature: 98.0°C
Temperature: 18.0°C
Voltage: 13.970 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79387 km
Time Indication: 0
Date: 2015.10.06
Time: 15:43:01
Injectors????
Any ideas.
I hate cars!
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 79364 km
Time Indication: 0
Date: 2015.10.06
Time: 07:59:46
Freeze Frame:
RPM: 2588 /min
Load: 20.4 %
Speed: 106.0 km/h
Temperature: 98.0°C
Temperature: 19.0°C
Voltage: 14.097 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79256 km
Time Indication: 0
Date: 2015.10.03
Time: 17:54:24
Freeze Frame:
RPM: 1520 /min
Load: 21.6 %
Speed: 61.0 km/h
Temperature: 96.0°C
Temperature: 15.0°C
Voltage: 14.097 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79364 km
Time Indication: 0
Date: 2015.10.06
Time: 07:59:46
Freeze Frame:
RPM: 2588 /min
Load: 20.4 %
Speed: 106.0 km/h
Temperature: 98.0°C
Temperature: 19.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 79364 km
Time Indication: 0
Date: 2015.10.06
Time: 07:59:55
Freeze Frame:
RPM: 2488 /min
Load: 30.6 %
Speed: 102.0 km/h
Temperature: 98.0°C
Temperature: 20.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 20
Reset counter: 255
Mileage: 79365 km
Time Indication: 0
Date: 2015.10.06
Time: 08:00:23
Freeze Frame:
RPM: 2331 /min
Load: 43.1 %
Speed: 95.0 km/h
Temperature: 98.0°C
Temperature: 18.0°C
Voltage: 13.970 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 79387 km
Time Indication: 0
Date: 2015.10.06
Time: 15:43:01
