Mine came with -[1BE] Sports suspension I would like to drop it down about 10/15mm as it does sit a bit high ... If I could lower it without making the ride harder then I would do it ....
So if someone knows what springs to use to drop it around 15mm without making the ride any stiffer than it is then tell me which ones to buy please
The SLine springs (1BV) will give you an extra 10mm, and on the plus side thats still OEM!
That's a good point Jay ... And I would like to stay OEM really .... Does any one have part numbers for the lower versions as I am going to TPS today so will get a price.
I have my sline suspension sitting in a box do you want me to have a look on the springs for you ???
You won't get much good handling unless you address the dampers at the same time. With springs such as eibach sportline Vogtland and the kW 50mm you will get the looks but I will change the dampers to sports one, preferably an inverted monotube type such as the B8 by Bilstien.
I would also be very much obliged for the colour codes off the springs a i need some to put back on my 2.tdi as ive had enough of my sportlines
