  2. Dismiss Notice
Glue/label removal
dirzhinis Jul 3, 2020
  1. dirzhinis
    dirzhinis New Member
    Hello,
    Any ideas how to remove this old glue/label? I've tried turtle bug & tar remover didn't helped. Please have a look to picture.
  2. Avatar
    snack-media
    Advertisement
  3. Tiprat
    Tiprat Member
    66
    If you have any WD40 or other such penetrating oil, spray it onto it or onto a rag leave it to soak for a short while then rub it off.
  4. dirzhinis
    Thank you didn't thought about wd40 will try for now
  5. Ricky Burrows
    Ricky Burrows Well-Known Member
    1,492
    734
    We got a few things at work i could recommend but you can try petrol before buying any of that as a quick cheap alternative.
  6. BakPak
    BakPak No Gear
    1,487
    218
    Acetone or nail varnish remover.
  7. AvantMike
    AvantMike Active Member
    311
    170
    43
    Have you tried t-cut or scratch X polish?
  8. dirzhinis
    Petrol & wd40 didn't worked. Any other ideas fellas ?
  9. dirzhinis
    Same with t-cut & x polish
  10. Ricky Burrows
    1,492
    734
    Best stuff I've used is paint thinners and a plastic trim tool scraper if that dont break it down your not getting it off without repainting it
    AvantMike likes this.
  11. AvantMike
    311
    170
    43
    I bought some polishing pads from fleabay to use with a hand-held drill/driver. they're more aggressive than a hand polish, by the same token they'll go through lacquer and paint quickly too.
    Meguaires Scratch X is the best polishing compound I've used so far.
    Unless of course you've tried machine polishing already.
  12. Avatar
    snack-media
    Advertisement
  13. BakPak
    BakPak No Gear
    1,487
    218
    If it is adhesive residue then I've found nail varnish remover or acetone works.
    Use a microfibre cloth for added abrasion.
  14. tr7
    tr7 Active Member
    170
    61
    If typical removers and even neat petrol hasn't touched it I'd be inclined to think that it has damaged the clearcoat
    Hoping I'm wrong. But your only other alternative is polishing it off/sanding then polishing it imo
    Ricky Burrows likes this.
  15. dirzhinis
    Acetone worked. Thanks.
