Genuine Audi UTR Camera Front And Rear **While Stocks Last**
creweaudiparts Aug 1, 2018
  1. creweaudiparts
    creweaudiparts t.fox@creweaudi.co.uk Audi Main Dealer
    293
    171
    43
    Hi Guys and Girls,
    We have some great deals on these cameras at the minute (while stocks last!)
    Price is for a 8V RS3 but if you message me ill check other car for you.
    RRP Price £430.00 Price £345.00 inc adaptor wire!!
    The UTR has high-quality lenses to record video in 1080p clarity and covers a 150 degree angle, giving an almost complete view of a vehicle’s surroundings when installed at the front and rear of the car.
    Videos are recorded onto the unit’s internal SD card, and can also be accessed through an iOS or Android app, which adds parking location and event functions.
    Features & Benefits:
    • Lens: 1080p at 60fps = clarity and smooth picture viewing
    • Fish eye records 150 degree angle = viewing angle to see the front wheel area.
    • Codec: Detects yellow, white & black colour = picks up number plates more clearly.
    • Hard wired to vehicle = Non visible driving position, and speed taken from CAN (more accurate than GPS)
    • Fixed & tethered to windscreen = Crash tested, doesn't become shrapnel in the vehicle.
    • GPS - Downloads your map location (and photos) upon parking (Multistory)
    • Radar - Records close incidents & people walking up to the vehicle.
    • G shock - Plays audible alarm once limit exceeded.
    • Security LED - Reassures occupants, warns people outside of the vehicle.
    • Voice Recorder (toggable) - Added in car safety, audible alarms on events recorded while not in the car.
    3 different operating modes:
    Standard:
    • Regular mode for recording.
    • Recording starts after the engine is turned on and ends after it is turned off.
    • Equipped with a ring buffer, meaning that when the storage is full, the oldest data is deleted to make space for new data recording(this also pertains to the other modes)
    • Data is stored on an SD card and will not be overwritten by Event or Parking Mode.
    Event Mode:
    • Impact triggered recording.
    • When acceleration sensor exceeds its threshold, it immediately begins recording the relevant data.
    • Sensitivity of the acceleration sensor is adjustable by the customer via the Audi UTR app.
    • Separate files are saved with a pre-defined length.
    • Data is stored on an SD card and will not be overwritten by Standard or Parking Mode.
    • Radar based recording.
    • Record mode will be activated once the engine is turned off.
    • System remains in stand-by mode until motion is detected by the radar sensor, then recording starts.
    • Sensitivity of the radar sensor is adjustable by the customer via the app.
    • More than 72 hours of stand-by time is possible.
    • Data is stored on an SD card and will not be overwritten by Standard or Event Mode.
    The Audi UTR app
    The Audi UTR app featured a user-friendly and intuitive interface, specifically designed for the Universal Traffic Recorder (UTR) and is available free of charge. Its capabilities include live viewing, data management, a car finder function and being able to adjust the recorder's settings. The seamless connection between the UTR and the smartphone occurs via a recorder-internal Wi-Fi hotspot. Users have the choice to access data from an SD card and use internal smartphone storage. All functions of the recorder can be controlled by the UTR app. The different features of the app are described as below:
    • Live View - Live images of both front & rear camera allow the customer to adjust them to the most suitable recording position.*
    • Video Gallery - Enable customers to watch recorded data directly from the SD card or the internal smartphone storage. The export of the data from the SD card to the smartphone is possible here.*
    • Car Finder - When the engine is turned off, the location-based information is saved via GPS together with the date, time and the latest pictures of both recorderes, to make it even easier for the customer to find their parked car.
    • Settings - Enable the configuration and control of the recorder. Allows the user to switch between the different modes and to adjust the acceleration and impact sensor as well as enable other functions.*
    • Menu - All functions of the UTR app require a Wi-Fi connection between the UTR and smartphone. Users will be notified based on events which have been detected by the radar and acceleration sensor.
    Ghost, q5man and Sandra like this.
  2. Avatar
    Google AdSense Advertisement
  3. RS3 S.
    RS3 S. Well-Known Member Team Daytona TFSI Owners Group Team V6 SQ5 owners group Audi Q5 S tronic
    565
    284
    These sound good, are they hard wired in & if so is it a big job?.
  4. creweaudiparts
    293
    171
    43
    Hi,
    @RS3 S. the time consuming part is hiding the wiring behind trims.The wiring part i believe to be pretty ok.
    RS3 S. likes this.
  5. neiller
    neiller Member
    65
    Will this work with an a4 b8 ?
  6. creweaudiparts
    293
    171
    43
    No unfortunately not.
  7. JJ_2018
    JJ_2018 Member
    57
    Hi a few questions...
    Firstly will this my A3 saloon s-line (2017) ?
    Does this have parking mode..I assume from the above it does.
    Lastly, how does this cameras features compare to that of the Thinkware F800 Pro?
    Thanks in advance,
    Josh
  8. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro Platinum Supporter S tronic Audi Main Dealer
    30,336
    13,203
  9. creweaudiparts
    293
    171
    43
    Hi,
    @JJ_2018 if you send me your REG or chassis on a pm i can check compatibility no problem.
  10. creweaudiparts
    293
    171
    43
  11. Tashfeen
    Tashfeen Moderator Staff Member Moderator Team Glacier TFSI Owners Group Team V6 VCDS Map User Team Scuba Supercharged Audi S4 Audi A3 Black Edition quattro
    5,727
    11,754
    PM sent
  12. Avatar
  13. Kaine19
    Kaine19 Stage 2+ S3 8P now gone. Hello 2016 RS3 :) TFSI Owners Group Audi S3 Black Edition DSG
    588
    242
    43
    Pm sent
  14. Audimad
    Audimad Well-Known Member
    706
    301
    Will these work on a 2016 A6 Ultra?
  15. Sandra
    30,336
    13,203
  16. creweaudiparts
    293
    171
    43
    Hi,
    @Audimad yes this will fit your A6.
    Give us a call
  17. Audimad
    706
    301
    How much please including fitting?
  18. creweaudiparts
    293
    171
    43
  19. RS3 S.
    565
    284
    ...........might be stupied question but would any main dealer be able to fit these ?. Reason i ask is mine could not even do the ''alarm chirp'' with V.C.D.S
  20. creweaudiparts
    293
    171
    43
    @RS3 S. yeh any main dealer or person good at elctrics should be able to!
    Let me know if you want one as there while stocks last
