  2. Dismiss Notice
G476 Short to Ground fault
Djwoody Dec 18, 2014
  1. Djwoody
    Djwoody Member
    480
    21
    Hi.
    My Cruise Control has stopped working on my A4 B8 and I have a fault coming up in VCDS which is:
    03182 - Clutch Position Snesor (G476) Short to Ground.
    I have replaced the G476 sensor (which is intergrated into the Master Cylinder) and the fault is still there.
    Does anyone have any information on this?
    Chris
    Wednesday,17,December,2014,19:06:20:62129
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: License Plate: 2014-12-17-CHRIS
    Address 53: Parking Brake Labels: 8K0-907-801-V1.clb
    Control Module Part Number: 8K0 907 801 E HW: 8K0 907 801 E
    Component and/or Version: EPB Audi B8 H05 0060
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    VCID: 316C81DF68DBEBA9D05-8064
    1 Fault Found:
    03182 - Clutch Position Sensor (G476)
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 240
    Mileage: 143530 km
    Time Indication: 0
    Date: 2014.12.17
    Time: 19:03:22
    Freeze Frame:
    Voltage: 12.00 V
    Count: 52
    Speed: 0.0 km/h
    Hex Value: 0x0263
    Hex Value: 0x0001
    Hex Value: 0x1010
  2. Avatar
    snack-media
    Advertisement
  3. V2brett
    V2brett Member
    47
    10
    Be interested to see a fix for this too mate as i have the same problem. Keep me posted on how you get on.
  4. Djwoody
    Djwoody Member
    480
    21
    Have you replaced the master cylinder?
    I changed mine and I still have the error and not fixed yet :-(
  5. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    7,173
    3,550
    When you see a short to ground quite often the problem is a blown fuse or supply issue.
    Here is some info on what the switch does it's for the A5 but is relevant
    http://www.audi-portal.com/en/diagnostic/sensors.html?sensor=476&model=6
    click on these links when you goto the page linked above for info on the sensor.
    Looking at the wiring diagram there appear to be 2 fused supplies going to the module
    Appears to be fuse 2 on fuse carrier ST1 and ST2 in fuse holder C
    This is located at the end of the dash on the drivers side
    Check fuse 2 in both ST1 and ST2 , shown as being a 5A fuse.
    Karl.
  6. V2brett
    V2brett Member
    47
    10
    No not yet bud it was going to be my next port of call, just with me doing mostly short journeys i dont miss the cruise that much.
    Reading that youve changed yours and still have the fault has put me off doing it though, 1 for the expense and 2 for the chance it wont work now.
    Do you have any other ideas or things your thinking of trying?
    Funny thing is my car shows no other indication of this fault apart from the parkbrake not auto releasing which is liveable with, ie it starts ok everytime.
  7. V2brett
    V2brett Member
    47
    10
    Thanks for the info desertstorm, i have checked both those fuses and they appeared to be ok. I will have a good read of that link though and see what i can find out.
    Brett
  8. desertstorm
    7,173
    3,550
    There is a connection to the EPB module that you can see on the above circuit diagram J540 is the module that controls that.
    V2brett likes this.
  9. desertstorm
    7,173
    3,550
    If the fuses are good I would use a multimeter and check that there is power on the 2 supplies feeding the switch, also check the fuses with a multimeter.
    Karl.
    V2brett likes this.
  10. V2brett
    V2brett Member
    47
    10
    Hi guys, just to update this thread i now have my cruise control and auto handbrake release all sorted for £50. It was the park brake module that was at fault.
    Just want to say thanks to Karl for the wiring diagrams as i studied these and decided to take the plunge and bought a used H revision module off ebay. My old module is an E revision like yours dj woody.
    Dj woody if you are going to also try this on yours i can help with sourcing a module, i missed 1 on ebay last weekend but the guy only got back to me today saying it hasnt sold. I think £40 would get it delivered to you.
    Cheers for all the help guys.
  11. desertstorm
    7,173
    3,550
    Glad it's sorted, and didn't cost too much.
    Karl.
    V2brett likes this.
  12. Avatar
    snack-media
    Advertisement
  13. dsw88
    dsw88 New Member VCDS Map User
    22
    Hi guys sorry to bump an old thread but i've currently got this problem on my A5 where the auto release wont work with no other warnings on the dash, anyone know where the EPB module is on the A5?
  14. vag-tech
    vag-tech Site Sponsor Site Sponsor Team Ibis VCDS Map User Audi A3
    336
    125
    43
    Live data possible on relevant measuring blocks (driver buckle switch; clutch switch; driver occupancy; etc)?
  15. R0cket
    R0cket Active Member Team Aruba Blue TFSI Owners Group Team V6 VCDS Map User Team Phantom
    162
    27
    I have an error similar but mines 14 defective. I’m guessing I’ll be replacing the sensor soon.
    first noticed the gear indicator was missing occasionally and then my hill hold assist said it was unavailable. Then the cruise control wouldn’t work at all and finally found out the handbrake needed manually pressing.
