Shoomakan
Grand Nagus
Good evening everyone,
I'm running into a problem with my S3 (1.8T AMK). A few weeks ago at a track event, car started to run out of fuel. Would hit 0.8 bar or so and then go lean and cut.
Been driving it around super gently when I had to, staying below the problem range. First assumption was pump, so I installed my new DW650 today. Sadly, problems persist. Here's what I've done so far:
Checked 4 bar FPR, working fine.
Checked injectors, seem fine.
Fuel pump wiring is correct, pump is priming and sending fuel. Problem has persisted across 2 pumps so I doubt that's the issue.
Hooked in a fuel pressure gauge and it seems ok. Over 4 bar at WOT, doesn't go below 3.5 at idle.
Car is full of gas.
I'm getting a MAF reading via the liquid gauge, but car hits the lean spot before g/s reading peaks.
I noticed that the Liquid gauge and my analog boost gauge are about 3 psi apart (0 indicated on analog gauge, 3 psi indicated in Liquid). Same relative difference at different boost pressures, as far as I can tell.
No ECU error codes via built in Liquid scanner.
Same problem as before. Hit boost, get to 0.7 or so and it cuts, goes lean. Idle AFR is fine, AFR at part throttle is fine.
Only thing I can think of at the moment is voltage at the fuel pump. Going to get in the car with a volt-meter and see if it's getting to 13.8V as it should. Otherwise, I'm at a loss.
Any tips/tricks to help me diagnose this? Anything I missed?
Thank you for your time.
Cheers.
Car is full of gas.
Cheers.
