Fuel pump relay problem
Eric ONeill
New to the forum,
Having trouble with my fuel pump relay had the car diagnosed, code it gave was for the fuel pump relay
Checked under the ecu but couldn’t seem to match the right relay with the new relay I had bought
Got a mechanic to give me a diagram but can’t find where slot one is (for the fuel pump relay)
Anyone had the same issue or know anything about this?
Eric ONeill
Here’s the diagram the mechanic gave me
jay1601
Little oblong shaped relay.
Will be under the ECU the numbers may be different as newer number tent to supseed the original ones
Eric ONeill
Heres under my ecu, can you tell which one it is?
Would the fuel pump replay be causing engine shake and stalling ?
jay1601
In that picture it’s the one on the right. (To the of 614 relay)
When had issues with my relay engine would cut out and when completely died wouldn’t start.
