Hi Guys and Gals,
Here's the story.
I have a pair of OEM Xenon headlights with Ballast and Bulbs for sale, which are suitable for a B6 A4.
Ideal as a (nearly) plug and play upgrade for those with Halogen headlights.
I purchased themto replace the halogen headlights in my A4, but at around the same time, came accross a pair of S4 headlights, which are bi-xenon, and fitted those instead.
These are the original Audi headlights, new and unused -(plugged in to test but never fitted or driven)
To fit, they are plug and play, however some work will be needed to get headlight levelling to work (using the original electric adjustment on the dashboard)
The headlight levelling motor connection on the xenon headlight is a 4 wire connection
The headlight levelling motor connectio on the halogen headlight is a 3 wire connection.
You will need to cut the 3 wire connector from the halogen headlight, and connect it to the wiring on the Xenon headlight. The wiring is:
Headlight levelling motor side------------- Car side
Blue -------------------------------------Black
Black------------------------------------ Brown
Brown----------------------------------- Blue
------------------------------------------White (no connection)
The wiring change is made inside the headlight, no changes are made to the car wiring.
If you don't care about electric headlight levelling (and to be fair how often do you adjust it) then this is a plug and play solution, and will work out of the tin.
If you want working headlight levelling, then it's probably about 10 minutes work, assumming you can solder.
The advantage of this is that you do not need to worry about where to fit the ballasts, as they fit into the headlight, and you do not need to worry about the beam pattern as they use the correct Xenon projector.
The Ballast is made my Valeo, and the Bulb's by Osram. The headlights have seen 0 miles, and are as good as new.
To be honest, I'm not sure how much they are worth and so am open to offers. I'm pretty sure originally, I paid £300 per headlight, and £400 for the ballasts and Bulbs.
If you live near me, then I would be willing to assist with fitting.
Cheers,
Ray
Here's the story.
Cheers,
Ray
