  2. Dismiss Notice
Front window steam up
Rob1967 May 20, 2017
  1. Rob1967
    Rob1967 Registered User
    When driving along and out side temperature starts to drop my scream starts to steam up an is annoyingly hard to clear.i press windscreen button and it blows cold air out fast to clear scream but as soon as I press it again it steams up any way to stop this
  2. Avatar
    snack-media
    Advertisement
  3. Simon968
    Simon968 Registered User
    384
    53
    Are you driving with the A/C on or in Econ mode?
    The only time I've had mine steam up was when it had been into the garage and they had turned the A/C off and I hadn't realised.
    I normally run mine in Auto mode and it's fine.
  4. S3Steve
    S3Steve Registered User
    1,604
    21
    If your windscreen is steaming up with the aircon on try selecting recirc this should stop the windscreen steaming up.
  5. Rob1967
    Thanks for reply
    I always use econ mode as thought auto mode used more fuel
  6. Furryhobnob
    Furryhobnob Registered User
    287
    102
    43
    Econ isn't air con, try putting the air con on with the air going onto the windscreen, will demist it quite quick
  7. Simon968
    384
    53
    Econ mode turns the A/C off.
    Probably uses slightly less fuel, but I can't say as I've really noticed much difference to my mpg with the A/C on or off in any car I've owned, so I just leave it on and enjoy the comfort :sunglasses:
  8. 1210tech
    1210tech Four Ring Fanatic
    698
    I always use AC mode but never have the air flow directed onto the windscreen, I always select dash vents and footwell vents or just dash vents on their own, never had the windscreen mist or steam up in any weather even with no air flow onto it
  9. Rob1967
    Ok thanks will try what you guys are suggesting
