View attachment 106007 View attachment 106005
So old pump tested using vcds, was squeeling and seizing even after removed and filter cleaned,
New pump fitted, fresh oil, vcds test and pump working away nicely, while under the car, the haldex coupling or (donut)as some folk call it was broke so had to cut off, the metal that's bonded to the rubber had failed so grinder out and cut a line at the bottom, then spun it round to cut another line then remove it in two halves(see pic) this part is a counter balance so no launches until a new one is fitted!!
Road test and still 2wd,
Propshaft is fecked
£1648 for a new fitted propshaft from Audi, but they can't get one as no uk stock and none from Germany, back order, so not an option
Sourced a low mileage used one, £600
Getting fitted next week.
What a ball ache!!!!!!
So found out why the prop broke, this is important to all s3 owners with dsg who like to launch their cars, both tuned cars & stock cars, there is a dog bone mount that needs uprated to reduce engine movement when launching, without this it's a certainty before the prop snaps.
I've been unfortunate to not have the dog bone mount fitted, it's cheap to do, around the £45 mark, so save yourself a big bill and get one fitted asap if you like to launch.
There's suite a few that are available eg: Vw racing, 034 motor sport.
Will update next week when the new prop and mount is fitted.
