Front seat removal
MrMarcus
Hi everyone.
I have an 2019 A4 B9 tfsi 40 which has the mild hybrid battery in the boot. At some point in the past I think its had white paint spilled on the passenger side. The passenger seat has probably been removed to clean the car. The footwell light under the seat no longer works. I have tested the led bulb and it works. There is probably a bent pin in the seat connector. Can anyone advise how I can unplug the seat without triggering an airbag light or worse blowing the airbag in the seat.
Mark
MrMarcus
I fixed the issue which was caused by a bent pin in the red connector. I had to remove the black connector in front of it. The ignition was off I didnt touch the yellow connector but the airbag light is now on. I have ordered carista which will hopefully clear the fault code.
