front parking sensors with ops
hollows wife
seen as car is in for damage repair thought i would add the front parking sensors .
but since my heads in meltdown mode
can anyone list me the pdc model part numbers that work with ops .
i know this one should 8P0 919 475 H as NHN has it fitted .
but the others for the 7x2 just describe "control unit for parking aid"
do, 8P0 919 475 N and 8P0 919 475 Q also work for ops ?
also i would assume similar modules from the vw range would also work ending in the same codes.
also where except audi can i get the switch and half loom to rear of car from in the uk . As it seems there's a 3 week wait.
hollows wife
seems no one knows what part numbers are required , or dont give a toss lol
-Ju-
Well-Known Member
I retrofitted it using the 8P0 919 475H module too
The looms I got from kufatec
hollows wife
thanks for the info , 1 more question the loom has 2 options of a single switch or multi switch dash 2012 ? cant even check as car is in body shop been stripped
-Ju-
Well-Known Member
Not sure tbh.
There are 2 versions of the dash switch set for the 8P3. The early one that has separate buttons that are individually replaceable or one where the buttons are part of a strip and obviously not separately replaceable. Could it be referring to this?
Also the 8P3 was also available with self park which had 2 switches on the dash.
My best guess would be the first scenario.
Did you check kufatec?
hollows wife
cheers pal
