Front fog light issue
  • Thread starter Deleted member 85022
  • Start date
D
Guest
wondering if anyone can shed any light on this?
My front fogs no longer work! I’ve tried different bulbs, lamps and the harness that runs along the front bumper but to no avail.
The switch no longer iluminates green when pulled out for the first click, but the rear fog still works on the second click.
Has anyone had a similar experience? I’m guessing either relay or switch? But he switch works fine for everything else?
If it is relay, does anyone know where it is? I’m assuming under the steering wheel somewhere?
Dan
This is for a B6 so it should be the same......
Relay Location
A/C Clutch Relay (if installed in any free position)
2 - Control Module for Multi-Function Steering Wheel
3 - Control Module for Multi-Function Steering Wheel
4 - Rear Lamp Control Module
5 - Rear Lamp Control Module
6 - Selector Lever Light Relay
7 - Fog Light Relay
8 - Daytime Running Lights Switch-On Relay
9 - Driving Light Relay
10 - Brake Boost Relay
13 - Park/Neutral Position (PNP) Relay
Thanks. I’m hoping it’s something easy. They worked before my cars engine **** itself, then they didn’t after. Thought I’d not connected it at the bumper but I checked it all and it wasn’t that!
