Think you might be right I've just looked at a pic and it looks like the sameIt might be bits of the breather on top of the oil filter housing. This goes brittle and breaks up. This happened to mine.
Sounds like the throttle pedal has failed, not sure if it's a similar set up as the b5.5 Passat but they could leak through the ECU housing seal and/or the bonnet cable grommet and that's right above the throttle pedal leading to water ingress. Inside the throttle pedal are two potentiometers, one reads from low to high and the other from high to low, worth a check.so i scanned the car Sat morning before taking it to garage. no faults what so ever. then i started it up and the revs don't pick up. re-scanned it and still no faults. so now i have a car that doesn't rev.
any ideas???
Congratulations on the new little one mate! The car will sort it's self out.
Did you figure out what the bits are in the oil yet
