Forge Cam and Block Breather Adaptors - Yay or Nay?
warren9022 Jun 14, 2018
  1. warren9022
    warren9022 Active Member
    407
    165
    43
    I'm wanting to re-do all my catch can pipework properly and replace the elbow that always breaks in the block, came across the Forge Adaptors but they are designed to go to AN10 hose (14.3 internal bore). Would these be ok to use as everything I've ever read says don't go smaller than 19mm?
    It will be a 3 port catch can so the 2 breathers won't be 'sharing' any pipework but just wanted some advice on whether they were suitable, it states suitable for any 1.8T engine but is this really the case?
    2001 S3 AMK
  2. Avatar
    Google AdSense Advertisement
  3. Rainbird
    Rainbird Well-Known Member
    417
    251
    Better to keep the ID as large as possible really. These are a tidy solution, but the decreased size almost halves the flow area you have to play with.
  4. badger5
    9,946
    2,239
    personally I would'nt go less than the 19mm of stock..
  5. warren9022
    407
    165
    43
    Thanks guys, back to the drawing board then......
  6. gokiwi64
    gokiwi64 Guest
    I have some pictures and details of what I used , will post up later (was all 19mm) into triple port catch can.
  7. warren9022
    407
    165
    43
    That would be excellent, thanks mate.
  8. Stuart B
    Stuart B Well-Known Member
    3,292
    712
  9. gokiwi64
    gokiwi64 Guest
    So here are a couple of picture, unfortunately the block connector is not anywhere near as clear as I thought it was, I will see if I can dig up something better.
  10. superkarl
    superkarl MAN OF STEEL
    9,894
    2,597
    034 motorsport Make a billet adapter that comes in either 3/4inch thread (too small) or a 1 inch push fit nipple (big enough)
