Dont have to take wheel liner arch off trust me I did a post to change fog light bulbs Sent from my SM-G960F using Tapatalk
You can pull it, but I wouldn’t, you’ll probably snap it just take the front half of the wheel arch liner off should be able to reach in
A guy told me to just lever off the rings on the grill and all 10 clips just snapped i have learned not to pull on Audi clips
You dont have to dismantle the wheel arch ita a tight fit you wont break it there a hole grab that and just pull firmly and even it just pops out look at my post Sent from my SM-G960F using Tapatalk
@paddy just get a little flat headed acrew driver and as tou look at the grille on the left just insert it in the bk off the grille and gently pull itnwill easily come away
Did you have any trouble putting it back on? I took mine off, and couldn't get them back properly, they just wouldnt snap into place. Like if i manage to get bottom clips to snap in, the top ones wouldn't and vice versa.
Yeah it's a bit of a pain to get back in if you look at it the clips slide in I think corner first it has a tab. Then top the bottom you have to squeeze then push in a little tap with palm of your hand and it's in probably take a couple of attempts Sent from my SM-G960F using Tapatalk
