  2. Dismiss Notice
  1. SamHendry
    SamHendry Active Member
    827
    165
    43
    Decided its time for one but found selecting one a bit of a minefield. Read the stickies and that gave me a sore head tbh I want to keep my fogs but not sure what core is best suited. I don't plan spending a lot so I'm guessing I need to buy a core then purchase pipe kit separate. What pipe size is recommended for retaining fogs?
  2. Avatar
    snack-media
    Advertisement
  3. Lavis89
    Lavis89 Well-Known Member Regional Rep
    2,039
    822
    I kept my fogs on my a3 using 63mm piping, pretty sure it's a bit easier on a s3
  4. SamHendry
    827
    165
    43
    Thanks lavis. Any recommendations for a core with 63mm inlet/outlet
    When searching the forum I keep reading about people fitting the welly cooler, does this core come with 63mm?
  5. VAG-Slag
    VAG-Slag Well-Known Member
    1,854
    442
    Agreed, there is way to much FMIC info in the stickys to make sense of...
    I've used one of these on my k300 hybrid A3:
    http://www.toyosports.co.uk/fmic-ffront-mount-turbo-intercooler-type-r-550x225x64mm-6699-955-p.asp
    I also removed the air conditioning condenser to allow me to sit the cooler back a bit, which meant no crash bar trimming and kept fogs AND grills:
    All my pipe work was from MrSilicone and AutoSiliconeHoses... I think they're the same entity anyway
    Couldn't comment on the welly cooler, not something i've ever really looked into... But I believe this is the basis for the welly cooler:
    Could be wrong though...
  6. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,233
    5,540
    To be honest mate its all in the stickies... 63mm pipe tucked into the bottom of the bumper will retain fogs and grilles, welly cooler is 76mm outlets but there are ones available with 63mm outlets... problem with the welly collers in general is they sit the outlets a little too high... people can generally retain the fogs but lose the grilles with these...
    There are loads of installs in the FMIC thread and while I know its a bit of a read you should find a setup that suits what you want to do and then go from there
    AH Fabrications V2 is the one that fits the most OE with least amount of modding... Airtec kits are starting to show on the market now and these seem ok too...welly coolers will always need a little more effort to fit and the finish varies depending on attention to detail and skill level
  7. VAG-Slag
    1,854
    442
  8. SamHendry
    827
    165
    43
    Thanks for the input vag slag plus tuffty. Decided ebay cooler is best suited for me mainly because it's cheapest. If after installation I can't retain grills then I'll either live with it or consider removing ac condenser. I'll report back :)
  9. daz-20vt
    daz-20vt Well-Known Member
    2,825
    585
    not sure removing the ac condensor will help at all with room.
    also go for the toyosport one in the link that vag slag posted as i heard some of the ebay cores were not flowing so well.
  10. VAG-Slag
    1,854
    442
    I'm sure removing the air conditioning condenser does 100% help with room...
    Try getting a 2.5" cooler to fit like above without removing condenser... Granted you have to trim the plastic front end for inlets/outlets but it allows you to sit the cooler back by at least an inch
  11. SamHendry
    827
    165
    43
    If I can find a toyosports core with 63mm outlets then I will go for that.
  12. Avatar
    snack-media
    Advertisement
  13. VAG-Slag
    1,854
    442
  14. VAG-Slag
    1,854
    442
    and yes, I know it says 64 but it's the same difference... Not as if that 1mm is gonna cause any issues!
  15. daz-20vt
    2,825
    585
    you will have to excuse my lack of knowledge as i explain what i mean lol
    ive removed my ac and behind the cooler there is an empty gap now
    problem is there is a f4ame which holds things such as headlights etc and cutting didnt look wise
    the cooler was wider than the frame so just cutting the bottom for the pipe outlets wouldnt work you would lose lots of the frame to fit that cooler
  16. daz-20vt
    2,825
    585
    the one in your link has 76mm outlets bud
  17. SamHendry
    827
    165
    43
    I confused the thickness with the outlet size. I was under the impression outlets were 76mm. :dejection:
  18. daz-20vt
    2,825
    585
    the toyosport cooler with 63mm outlets is too small for the s3
    there are a few coolers on ebay with right size core and outlets but like i say they didnt flow well
    just so you know
    id stick with something proven but your shout bud
  19. VAG-Slag
    1,854
    442
  20. VAG-Slag
    1,854
    442
    Sorry see, what you're saying about the cooler being bigger than the plastic frame...
    Also, what makes you say this cooler is "too small" for the S3? . . I run one with a k300 hybrid which flows more than a k04 and it deals with AIT's NICELY! :icon thumright:
    You gotta remember that these larger 76mm coolers are overkill if anything, some of the most powerful cars on the forum run them!
  21. SamHendry
    827
    165
    43
    That 550x225 is exactly what I'm after. Fairly priced as well. Cheers dude
  22. daz-20vt
    2,825
    585
    ah fair enough
    i suppose it depends on your future set up?
    plus that cooler would be loads easier to fit lol
  23. VAG-Slag
    1,854
    442
    They're good coolers, no doubt...
    Exactly what I was gonna say daz... If you're sticking K04 then should be fine, if you think you might wanna upgrade turbo in the future then worth going for the bigger cooler
  24. antwan64og
    antwan64og Well-Known Member
    1,132
    298
  25. mark_S3
    mark_S3 Team Silver
    823
    320
    I opted for the Wellycooler at 600x300x100 but wanted to keep my grilles (not fussed about fogs) so decided to go custom.
    So I brought the Toyosport Cooler and selection of pipework.
    I then had the cooler custom fabricated. The 76mm exits where cut off, new flared exits with 63mm alloy pipework welded on.
    Just fits snug.
    craigt1985 likes this.
