Facelift FL Tick / Rattle
c2wak May 14, 2018
  1. c2wak
    c2wak New Member
    21
    12
    Hi all,
    Started a new thread now we know a bit more about this issue.
    So as you know we have a metalic noise from the loose exhaust valve pivots. This is a given, Audi replace backboxes for this.
    We have a cold start Tick / Rattle which can be hidded by starting in Dyamic or mapping it out and we know this is to do with the start up cycle and is normal.
    For us with a Decat, we get the cold startup rattle / tick all the time. In a nutshell we have had custom decats, Miltek, Scorpion so we know its not them. We now have 3 different back boxes, Miltek, Scorpion, and Audi and they all still have this issue. But closer investigation shows this is coming from the front of the car. Alot of suspicions are the Wastegate.
    So the noise is always there its just not aparent with a cat and the decat exhibits the noise, or does the change in pressure cause the noise?
    What resolutions do we have so far:
    1) Put original cat back on (thats just ****)
    2) Try a sports cat? (expensive option)
    3) Try and get Audi to look it as a fault? - They may just say - put the cat back on.
    So completely ****** off with this car now. 56k and cant even stick a decat on it without it sounding like a bag of smashed hammers.
    Rant over. Anyone else with any insight feel free!.
    KKOG and JamesCrs3 like this.
  2. Avatar
    Google AdSense Advertisement
  3. Dan_DJT
    Dan_DJT RS3 Saloon Team Floret Silver Audi RS3
    170
    118
    43
    I feel that the noise you talk about will only go via a remap to change wastegate position. Be interesting to know if cars with remaps also have the same noise
    It is annoying and does spoil the whole user experience a bit.
    Sent from my ONEPLUS A5010 using Tapatalk
    KKOG likes this.
  4. c2wak
    c2wak New Member
    21
    12
    Mines mapped Dan and it still does it. That being said, I dont know if its been changed as you mention it to change the wastegate position. Where did you get the information about the Wastegate position?
  5. c2wak
    c2wak New Member
    21
    12
    Ah i think you mean what Aoon said in an ealier post about the cold start the Wastegate is fully closed, this isnt the cold start thats the issue. Same noise just all the time.
  6. Dan_DJT
    170
    118
    43
    Yeah it was mentioned a while back on another post but I think the wastegate is fully open not closed. Fully open would allow gas to bypass the turbine straight into the cat to help with heating up the cat. That combined with retarded ignition and injection makes the loud noise. On my car the same noise is present when fully warm but not as loud, I hear it more when driving next to a wall etc. My view is that at part load low rev driving the wastegate is open as no or little boost is needed, and the noise is produced. At higher load but still low revs the noise is still there but as soon as the revs rise a little the turbo is called upon (and wastegate moved towards being closed) and the noise is replaced by the turbo as it spools up.
    I imagine that some remaps may only focus on high load changes, I am sure that with the right resources the low load wastegate control could also be changed.
    Obviously this is all just my opinion but is based on 20+yrs working in engine calibration development.
    KKOG and c2wak like this.
  7. Behind The Bins
    Behind The Bins Well-Known Member
    345
    254
    Are we talking about a constant ticking noise which can be heard at low speed?
    I have this, standard non sports exhaust
  8. Dan_DJT
    170
    118
    43
    Yeah thats the one, sports exhaust does it too
    sve170 likes this.
  9. Behind The Bins
    345
    254
    Any fix? It can be annoying
    I suppose it’s pointless booking it in with Audi if the replacement part will do the same thing
  10. c2wak
    c2wak New Member
    21
    12
    I got a custom decat and only noticed with decat. But my exhaust is the RS upgrade but it occurs even with scorpion and miltek systems as low speed.
  11. billymc92
    billymc92 2018 Ara Blue Facelift RS3
    630
    701
    93
    Here’s a few examples he is talking about. I’ve had it since February. Another boys just messaged me on Facebook today saying he has just got it after fitting same full milltek as me.
    c2wak likes this.
  12. Avatar
  13. c2wak
    c2wak New Member
    21
    12
    Thats exactly the one Billy thanks for posing those.
    billymc92 likes this.
  14. c2wak
    c2wak New Member
    21
    12
    This lad has a Miltek Sports Cat so we know it doesnt cure it totally. This was found thanks to James from another forum so thought i would share
    "I'm getting a "ticking" sound that's like an exhaust leak but after much inspection, we've chalked it up to being exhaust gas pulses that are more audible with the removal of the stock cat. You can only hear it faintly at low speed, load and rpm. Otherwise you don't notice it."
  15. billymc92
    630
    701
    93
    So must be the wastegate. Could you tell me what the wastegte is and what does it do @c2wak
  16. Behind The Bins
    345
    254
    Thanks I’ll do the same as you and record
    Have to say mine doesn’t appear anywhere near as bad as yours
    FL standard exhaust
  17. c2wak
    c2wak New Member
    21
    12
    You have the same tick only quieter but with a standard FL exhaust, no decat all the time. Well at lower revs more noticable?
  18. Behind The Bins
    345
    254
    Noticeable ticking noise around town
    So yes lower revs
  19. JamesCrs3
    JamesCrs3 Active Member
    246
    230
    43
    Yep, I've had a full scorpion system fitted, however opted to have the cat put back in because there is no way I can drive the car with that rattle, just sounds broken.
    @billymc92 Someone correct me if I'm wrong but as I understand the wastegate helps control the boost pressure in the turbo by opening and closing in order to regulate the flow of exhaust gases through the turbine.
    I'd guess that our cars have a flawed wastegate mechanism and that's why we are experiencing this dreadful sound.
    This theory is backed up pretty clearly by the fact people with turbo upgrades have no such issue.
  20. billymc92
    630
    701
    93
    Not a easy fix then, only cure is to get a new turbo then?
  21. JamesCrs3
    246
    230
    43
    Well that's the question, really we need someone who knows about this stuff to investigate and find us a solution!
  22. H4RDYRS3
    H4RDYRS3 Member
    20
    It may be possible to get an uprated actuator fitted (adjustable), then more tension/preload can be added to keep the penny flap closed until its on boost, it sounds to me like the penny flap is loose and causing the rattle off boost.
  23. H4RDYRS3
    H4RDYRS3 Member
    20
    Forge do list an actuator for the RS3 but not sure if its for the new one.
  24. JamesCrs3
    246
    230
    43
    I thought an uprated actuator is only really needed when boost has been increased and thr standard spring isnt up to the job of keeping the waetegate shut?
  25. H4RDYRS3
    H4RDYRS3 Member
    20
    But with an uprated one you get adjustment on tension, tensioning up the wastegate penny flap may just cure the rattle, I'm gonna look at ordering one and get JBS to fit it and check/set up on dyno.
    Will let you all know.
    JamesCrs3 and billymc92 like this.
  26. billymc92
    630
    701
    93
    I take it you have the decat rattle too?
  27. T-800
    T-800 Pending Deletion VCDS Map User
    3,128
    3,060
    Billy
    Waste gate on the PFL CEPA/CEPB engine
    You can just see it to the right of the compressor wheel
    On the FL Daza engine
    But this time on the back of the new Turbo setup, you can see the actuator rod/hinge assembly.
    KKOG and billymc92 like this.
  28. H4RDYRS3
    H4RDYRS3 Member
    20
    yes billy I have the rattle.
  29. H4RDYRS3
    H4RDYRS3 Member
    20
    T-800 is that the stock turbo on the bot pic ?, if so the std actuator looks adjustable.
  30. T-800
    3,128
    3,060
    Stock Turbo.
    I’d be careful messing with it though as it’s preset.
    Another picture (mine)
    I’ve watched it on a cold start and it doesn’t move at all so no play in it.
    KKOG likes this.
  31. H4RDYRS3
    H4RDYRS3 Member
    20
    Do you get the tick mate ?, are you decatted ?
  32. T-800
    3,128
    3,060
    No Tick here.
    Standard car though.
  33. Avatar
  34. Aoon_M
    Aoon_M Well-Known Member
    464
    416
    The rattle comes from the wastegate, it is a vacuum actuated wastegate now instead of boost actuated. You need to understand how boost actuated wastegates work really but I will explain the best I can!
    On a pre facelift RS3 8V with its boost actuated wastegate it remains shut when the duty cycle of the n75 is zero. It is fail safe this way. So on a cold start, the wastegate is shut.
    On a facelift car the wastegate is reversed as it is vacuum so with n75 duty cycle zero on cold start the wastegate is wide open and it rattles.
    Mappers need to set the wastegate duty cycle to 100 on cold start to stop this from happening. The reason its wide open on cold start is all to do with emissions and to get the cats up to temp as fast as possible.It is impossible to have the wastegate open on a cold start on a boost actuated wastegate
    When you put a fl car into dynamic after its cold start cycle the wastegate jams shut (duty cycle 100) to aid spool! In comfort it stays open, its a very complex backwards system they have in the new engine but all for emissions purposes
    KKOG, terminator x and deepy like this.
  35. Behind The Bins
    345
    254
    So are we saying we just have to accept it
  36. Aoon_M
    464
    416
    Who knows. It can be fixed with mapping, I don't know if Audi will patch it with a software update as I say it is to do with emissions,
  37. billymc92
    630
    701
    93
    So is there a way a mapper can stop it from the constant rattle as all us decatters have a constant rattle when under load. Not a cold start issue
  38. Behind The Bins
    345
    254
    Agreed the cold start is one thing that goes away quite quickly
    It’s the constant ticking that’s annoying, but if some people don’t have it surely it’s fixable by Audi, I don’t want mine mapped
    b11mey likes this.
  39. Aoon_M
    464
    416
    Its all in the mapping, the cold start one is a simple fix but when you are in drive the wastegate being backwards I'd imagine its extremely difficult to re write the full PID tables that control the actuator.
    The waste gates default position is open and the pid is all backwards so I don't know really. What would work is a boost actuated wastegate! I believe the n75 is backwards compatible with the pre facelift one. But you'd need major modifying to the turbo to change it to boost actuated.
    All Iroz big turbo cars are switching to boost actuated
  40. D0C
    D0C Well-Known Member Team Nardo Team Panther TTRS Audi RS3
    2,672
    2,420
    Great to see you on the forum again, Aoon. Always explain things well. Hope the R8 is fun!
    Aoon_M and terminator x like this.
  41. c2wak
    c2wak New Member
    21
    12
    Be lovely to think Audi would accept this as something that needs investigating?
    It's a noise that's always there, it's just only heard when the cat is removed. Surely they would have heard it while testing?!. Not sure at what stage they are tested. I have never heard of a car that cannot have it's cat removed. Maybe it was done on purpose as part of a scheme to prevent people doing it based on emissions?!.
  42. JamesCrs3
    246
    230
    43
    Good info, however doesn't really explain why it is rattling? Surely every car with a vacuum wastegate doesn't make this sound?
  43. T-800
    3,128
    3,060
    Here's a clip of the DAZA engine at cold start cycle.......
    Another when warmed up
