Thought I’d change the plugs and do a mini write up procedure.
Step 1
Remove Plastic engine cover
//uploads.tapatalk-cdn.com/20200501/787eb3a0dd6d2363d829ac1f95ad3a1a.plist
Step 2
Unplug Coil packs
Step 3
Unplug Cam sensor
You’ll need to pull back on the red locking tab then push down on the black tab
//uploads.tapatalk-cdn.com/20200501/5460ff373fc4cb4f47410c426d2b60bc.plist
//uploads.tapatalk-cdn.com/20200501/279a6870df5bcdf9d2b69399dbe6d459.plist
Step 4
Unclip the breather hose from the inlet pipe, then unclip the same hose from its securing clip on top of the engine.
Then pull the breather valve off it’s mounting
Then lay it forward out of your way
Step 5
Locate the 10 mm nuts that hold the wiring carrier in place and undo them.
Once undone you can lift it off towards the inlet pipe
You can then undo all 5 off the studs that hold the coil packs down.
//uploads.tapatalk-cdn.com/20200501/8f7f2b191f072b5f9a29f80baf50d29e.jpg
Step 6
You can now access and gently pull up on the coil pack to get to the plug.
Insert your spark plug socket with a suitable extension and undo the old plug.
New Plugs tend to come ready gapped but no harm in checking them.
Standard is 0.026 these were all set at 0.025 so I left them at that.
//uploads.tapatalk-cdn.com/20200501/5bd087a0ab59522d303e5b3a2729e63e.jpg
//uploads.tapatalk-cdn.com/20200501/4e67884416cc3ee58faca6df7b6a8343.jpg
Step 7
Gently insert new plug into the hole and start screwing it in by hand with the extension piece.
//uploads.tapatalk-cdn.com/20200501/2365feaf9f15f31bd6db063f506f637b.jpg
Once it’s finger tight get your Torque wrench and tighten to 30nm
//uploads.tapatalk-cdn.com/20200501/825c2782e6885fdba19999092151d4ca.jpg
Step 8
Smear a ball of Dielectric grease into the Coil pack opening.
//uploads.tapatalk-cdn.com/20200501/507e2f8ee494903e77158177c9de2db2.jpg
Then insert the coil pack back into its opening.
Repeat for the other 4 plugs / coils.
Insert threaded studs to secure coil packs and torque to 5nm.
//uploads.tapatalk-cdn.com/20200501/d20ae303b905f777a66b34de5d680392.jpg
//uploads.tapatalk-cdn.com/20200501/bcc4d51fde876757c143b7c72ca79f05.jpg
Refit the cable carrier and secure with the 3 nuts torquing to 5nm.
//uploads.tapatalk-cdn.com/20200501/e1a52245a24271d496d58e1bd1724694.jpg
Reconnect coil connections / camshaft sensor
Lastly refit the breather hose starting with mounting the valve back on
//uploads.tapatalk-cdn.com/20200501/c48e69f78390e5fb784ae04a7614e243.jpg
Put the hose back in it’s clip and reconnect to the inlet pipe.
//uploads.tapatalk-cdn.com/20200501/b06ceb600ed1c8b9c9d33e697b535ce1.jpg
Refit your engine cover.
Step 1
Step 2
Unplug Coil packs
Step 3
Unplug Cam sensor
Step 4
Step 5
Step 6
Step 7
Step 8
