Fitting facelift stalks, slip ring and wheel to pre-facelift car
Audigit
Active Member
I have had a search (granted, not too in depth) for anyone that has done as titled...
I've got a FB steering wheel on the way from an A4 but was wondering if it would be easier to fit the facelift slip ring at the same time? Then I spotted the stalks ate different on the facelift so got to thinking about fitting them too...
So my question is, if I get the facelift stalks that are the equivalent to mine (same functions) and slip ring, would I face any unusual issues with fitting them and the flat bottom steering wheel?
My long term goal is to replace as much as I can with facelift items, already have the led rear lights and correct adapter loom on the way and started collecting the window switchs...
Sent from my E6853 using Tapatalk
makelja
BTDT.
The stalks work the same as pre-facelift. You just have to calibrate the steering angle sensor with VCDS.
