Fiscon Basic now rear Speakers Don't work
stevob
Hi Guys I have recently fitted a Fiscon Basic Blue Tooth system to my 2007 Audi A3 it has a quad lock connectors.
It all works apart from my rear speakers.
Can any help i am pretty sure some pins just need changing around in the part B block ??
the rear speakers don't work completely or just when you using bluetooth function?
they don't work completely only a slight hiss can be heard
so the speakers worked correctly before mounting it right? If yes, double check if it was correctly fitted, then if it's all right probably the BT system disabling them.
ok cheers will check the wiring is different. do the rear speakers have an amp ?
depend on version of car, (if u got bose sure yes) anyway probably yes.
