  2. Dismiss Notice
First vcds scan gave me the creeps...
Andreashadji Oct 8, 2018
  1. Andreashadji
    Andreashadji Active Member
    197
    31
    ok so i scanned for the first time my A3(8p).2012 2.0Tdi quattro and i got a shtload of faults...
    mind you the car runs fine and i dont have any warnings lights on.
    so here it goes:
    any thoughts on how to proceed?
    Monday,08,October,2018,17:13:59:39744
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170203 DS267.2
    www.Ross-Tech.com
    VIN: WAUZZZ8P0CA125739 License Plate:
    Mileage: 98280km-61068mi Repair Order:
    Chassis Type: 8P (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 22 25 37 42 44 46 47 52 55 56 61
    62 72 77
    VIN: WAUZZZ8P0CA125739 Mileage: 98280km-61068miles
    01-Engine -- Status: Malfunction 1010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    77-Telephone -- Status: Malfunction 0010
    Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
    Part No SW: 03L 906 018 AL HW: 03L 906 018 AG
    Component: R4 2.0l TDI H25 9978
    Revision: 41H25--- Serial number: AUX7Z0L1FN30AA
    Coding: 00190032042601080000
    Shop #: WSC 54821 001 1048576
    ASAM Dataset: EV_ECM20TDI01103L906018AL 003005
    ROD: EV_ECM20TDI01103L906018AJ.rod
    VCID: 74E00792DF206FE1FD-8020
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 14426012092400FF281206E790220052390000
    Shop #: WSC 06314 000 00000
    VCID: 7BF22CAEFA7E2099BC-802E
    2 Faults Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:30
    Freeze Frame:
    Count: 2
    Count: 2
    Count: 4608
    Count: 8194
    Count: 37120
    Count: 1
    Count: 253
    Count: 0
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 73
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:30
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
    Component: KlimavollautomatH09 0180
    Revision: 000733 Serial number: 8P0820043BN
    Shop #: WSC 00000 000 00000
    VCID: 79FE36A630421289AE-802C
    1 Fault Found:
    00532 - Supply Voltage B+
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:10
    Freeze Frame:
    Voltage: 8.80 V
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
    Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
    Component: BCM PQ35 M 110 0667
    Revision: AJ110667
    Coding: 46000A2FE0051AC0207040E02100085C42762BAA216DD12AE4008F840041
    Shop #: WSC 06314 123 12345
    VCID: 3F8A98BEAEE6FCB9D0-806A
    Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSEN H04 0003
    Coding: 024C2D
    5 Faults Found:
    01504 - Bulb for License-Plate Light (X)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 97924 km
    Time Indication: 0
    Date: 2018.05.16
    Time: 16:54:57
    Freeze Frame:
    Term 15 On
    Voltage: 14.60 V
    ON
    ON
    Term 50 On
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 97924 km
    Time Indication: 0
    Date: 2018.05.16
    Time: 16:54:57
    00446 - Function Limitation due to Under-Voltage
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 19:42:58
    Freeze Frame:
    Term 15 Off
    Voltage: 17.75 V
    OFF
    OFF
    Term 50 Off
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 19:42:58
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:02:27
    Freeze Frame:
    Term 15 Off
    Voltage: 9.00 V
    OFF
    ON
    Term 50 Off
    OFF
    OFF
    Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X2.clb
    Part No SW: 8P0 919 475 N HW: 8P0 919 475 N
    Component: PARKHILFE 8K H01 0140
    Revision: 11001001 Serial number: 12511203701432
    Coding: 100203
    VCID: 499E8666E02242097E-801C
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:31
    Freeze Frame:
    Temperature: 22.0°C
    Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
    Component: Airbag AU1042 H10 0250
    Revision: -------- Serial number: 003JU00606EZ
    Coding: 30314238303830303035554A304C38503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 52ACA10A057401D10F-8006
    Crash sensor for side airbag: driver side:
    Serial number: 3572DRB40000E72110CN
    Crash sensor for side airbag: front passenger side:
    Serial number: 3582DRB40000E71C515W
    Crash sensor for side airbag: rear: driver side:
    Serial number: 35128RB40000695CAE7
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 35228RB4000068A9303F
    Crash sensor for front airbag: driver side:
    Serial number: 35547RB400006935CC2T
    Crash sensor for front airbag: front passenger side:
    Serial number: 35647RB400006935D18Q
    1 Fault Found:
    13635840 - Supply voltage
    U1011 00 [008] - Voltage too Low
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
    Component: J0527 H38 0070
    Coding: 0004042
    VCID: 46848D5A313CAD7193-8012
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H02 0100
    No fault code found.
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 932 N HW: 8P0 920 932 N
    Component: KOMBIINSTR. VDO H03 0150
    Revision: D0H03002 Serial number: 2241L002058049
    Coding: 0293028
    Shop #: WSC 35468 001 1048576
    VCID: 3F8A98BE6EE6FCB9D0-FFFE
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:19
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 40
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:19
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 N HW: 1K0 907 951
    Component: J533 Gateway H43 1623
    Revision: H43 Serial number: 280112F2002005
    Coding: 352102
    VCID: 3B72ECAEBAFEE099FC-806E
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:10
    Address 22: AWD Labels: 0AY-907-554-V1.clb
    Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
    Component: Haldex 4Motion 3018
    Coding: 0000005
    VCID: 45868A560C3AA6699A-8010
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:10
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H03002 Serial number: AUX7Z0L1FN30AA
    VCID: 3F8A98BE6EE6FCB9D0-806A
    Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0220
    Revision: 0000012S Serial number: AUZBZ7MD202504
    Coding: 0225755
    Shop #: WSC 63481 001 187288
    VCID: 3460C79257A02FE13D-8060
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 77
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 07:57:27
    Freeze Frame:
    Voltage: 11.80 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 77
    Mileage: 96890 km
    Time Indication: 0
    Date: 2018.03.19
    Time: 07:51:14
    Freeze Frame:
    Voltage: 11.80 V
    Mileage: 655350 km
    Count: 65535
    Clock: 255:255
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
    Component: Tuer-SG H04 0101
    Coding: 0131324
    VCID: 499E8666202242097E-801C
    2 Faults Found:
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    01034 - Electric Window Thermal Protection Active; Driver
    000 - - - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 232 3305
    Revision: 00H22000
    Shop #: WSC 02069 000 90108
    VCID: 377AF09E46D6C4F918-8062
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:32
    Freeze Frame:
    Voltage: 10.63 V
    PD
    Temperature: 18.0°C
    RPM: 1498 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
    Component: AB2 SUBWOOFERBOXH07 0180
    Revision: 00006 Serial number: 92158129062629
    VCID: 3664FD9A41DC3DF103-8062
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:01:01
    Freeze Frame:
    Temperature: 26.0°C
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:22
    Freeze Frame:
    Temperature: 26.0°C
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
    Coding: 0131324
    VCID: 4A9CB96A2524491177-801E
    1 Fault Found:
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
    Address 55: Headlight Range
    Cannot be reached
  2. Avatar
    snack-media
    Advertisement
  3. mikep99
    mikep99 Active Member
    352
    193
    43
    looks like you (or someone else) had the battery disconnected on 4th September....
    If I were you, I'd clear them all and give it a scan after you've done a few miles over the next few days/weeks.
    See if anything pops up then.
    ta
    Mike
    Andreashadji likes this.
  4. maxpayne
    maxpayne Well-Known Member
    1,012
    217
    Have you tried doing a reset and see which ones come back?
  5. Andreashadji
    197
    31
    Thanks for quick replies guys.
    Indeed the battery was disconnected for a period of time while in the sellers yard(2nd hand buy).
    I will clear all and give it another go.
  6. ch1z64
    ch1z64 C'mon you's bhoy's in Green Silver Supporter VCDS Map User
    4,066
    869
    Always mind when doing a scan off your car to do an AUTOSCAN first and save it as that will go to your rosstech folders thats only if it is a Genuine cable . Plus check you have updated to newest software for your cable .
    Now if you buy a 2nd hand cable and it hasn't beem registered it can be but you will pay to do so as you become new owner off cable , worth it as you will get all the support you need lets just say something happens with cable they at least can advise or replace if faulty but if not registered no joy
  7. Andreashadji
    197
    31
    ok so i did a second scan, same faults appeared cleared them all,another scan and these are the results:
    i m trying to activate the oil temp function on the DIS but all the directions i found suggest instruments-17 and then coding-7 and long helper which doesnt exist..
    thoughts?
    Monday,08,October,2018,22:56:29:39744
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
    VCDS Version 17.1.3.0 (x64)
    www.Ross-Tech.com
    62 72 77
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    VCID: 74E00792DF206FE1FD-8021
    Readiness: 0 0 0 0 1
    Revision: 00H31001
    VCID: 7BF22CAEFA7E2099BC-802F
    VCID: 79FE36A630421289AE-802D
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 72
    Mileage: 98206 km
    Time Indication: 0
    Date: 2018.09.04
    Time: 00:00:10
    Freeze Frame:
    Voltage: 8.80 V
    Revision: AJ110667
    VCID: 3F8A98BEAEE6FCB9D0-806B
    Coding: 00DD13
    Coding: 024C2D
    Coding: 100203
    VCID: 499E8666E02242097E-801D
    VCID: 52ACA10A057401D10F-8007
    Coding: 0004042
    VCID: 46848D5A313CAD7193-8013
    Coding: 0293028
    VCID: 3F8A98BE6EE6FCB9D0-806B
    Coding: 352102
    VCID: 3B72ECAEBAFEE099FC-806F
    Coding: 0000005
    VCID: 45868A560C3AA6699A-8011
    Coding: 0225755
    VCID: 3460C79257A02FE13D-8061
    Coding: 0131324
    VCID: 499E8666202242097E-801D
    Revision: 00H22000
    VCID: 377AF09E46D6C4F918-8063
    VCID: 3664FD9A41DC3DF103-8063
    Coding: 0131324
    VCID: 4A9CB96A2524491177-801F
    Address 55: Headlight Range Labels: 4F0-910-357.lbl
    Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
    Component: AFS 1 H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000028
    VCID: 2B52DCEE8A9E70196C-807F
    Subsystem 1 - Part No: 7L6 941 329 B
    Component: AFS-Modul links H02 0005
    Subsystem 2 - Part No: 7L6 941 329 B
    Component: AFS-Modul rechtsH02 0005
    Address 56: Radio Labels: 8E0-035-192-RNSE.clb
    Coding: 0225755
    Address 61: Battery Regul. Labels: 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 1623
    Coding: F30F185A
    VCID: 71EE0E86A8325AC916-8025
    Subsystem 1 - Part No: 1K0 915 181 H
    Component: J367-BDM
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0131288
    Shop #: WSC 06314 000 1012544
    VCID: 428C914A1D149151BF-8017
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0131288
    VCID: 4382944E020E9859B4-8017
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 A HW: 8P1 862 335
    Component: FSE_256x BT H44 0660
    Revision: 00000000 Serial number: 00000005495164
    Coding: 0011411
    VCID: 3566FA965CDA36E90A-8061
    End-------------------------(Elapsed Time: 02:38)--------------------------
  8. ch1z64
    4,066
    869
    Might be worth updating your cable
  9. Andreashadji
    197
    31
    does anyone know why on some modules the workshop code is just zeros?
    for example:
    Coding: 0000005
