ApolloS3
Hi everyone,
I did have 3 problems but now one is fixed ( Had a bolt head snap on the number plate leaving the rest of the bolt still in the bumper with no easy way to get it out - lots of pulling and twisting did the trick in the end ).
Anyway, so ive had the car for 3 weeks, and now i have a blown flex pipe on the exhaust system,
Was told it would be about £1000 replacement of the whole downpipe section from audi, ~£500 local garage or ~£200 for a repair, gutted as ive only had the car 3 weeks.
Ive just been quoted £75 from a place called prospeed exhausts in Cardiff which sounds very reasonable ( if the flex pipe is easy to get to, if not he said £125, still reasonable i think ).
Just want to know if anyone has had this happen, if so can it be fixed or does it need replacing?
Second problem is the rear washer doesnt work, ive used needles to poke in the outlet and clear as much of the blockage as possible but still no luck, when i hold the washer for the back, some water squirts out but then stops completely, if i use a needle again and repeat, same thing happens.
Will be very grateful for any info,
Jordan
Jordan
