Had a slight 'moment' the other night where I had to pull up a bit smartish due to a pair of foxes humping in the middle of a country lane I happened to be 'travelling' down...
No harm became the foxes or the car but... the brakes felt horrible...
After a little bit of reading up and a little chat with ASN's resident brakespert
@Prawn I decided on a set of DS1.11 pads from Ferodo...
Here are a couple of graphs taken from Ferodo's web site...
Essentially I was going to go for DS3000 but... they have a habit of wearing out discs (by all accounts) and also wearing them selves out too... the DS1.11 pad is described thusly...
Several brake pads on the market boast 'ceramic' technology. DS1.11 is the real thing. It is based upon a chemical family known as Siloxanes. Unlike carbon based materials, siloxane chains do not decompose at high temperatures and so DS1.11 keeps on working up to the highest temperatures a brake pad could ever see. That means it won't fade and has excellent life, the best in the Ferodo Racing range. Moreover the performance remains exactly the same throughout the pad's (long) life. It is formulated to provide a very flat friction profile at a medium/high level of friction. The pad compression is very low, always, and so pedal travel is short and consistent.
The main characteristics of DS1.11 are:
- Heavy duty endurance material
- Applications - touring car, GT, single seat
- Average friction coefficient 0.46 over working temperature range of 200°-700°C
(Excerpt taken from
http://www.ferodoracing.com/products/car-racing/racing-brake-pads/ds1-11/)
They are an endurance pad and as you can see from the graphs perform better overall than the DS2500's I did have...
So Bill ordered some up and...
..and swapped them out with the DS2500's... (DS2500 on left, DS1.11 on right
One thing to note though is that the normal pad for my AP calipers is supposed to be 55mm deep... this is a bit of a problem on my rotors as they are designed for a 50mm pad... this was causing me issues with pad knock off as the inboard pad over hung the inside edge of the rotor and the outboard pad back plate was catching the bell as it wore down...
Ferodo list the FRP3083 as the front pad...
http://ecat.ferodoracing.com/car-racing/brake-pads/FRP3083
...and the FRP3115 for use for when the caliper is used as a rear...
http://ecat.ferodoracing.com/car-racing/brake-pads/FRP3115
When placed together the look very similar..
...however you can see they are not as deep (obviously)...
..and a slight difference on the sides...
Reality was I either tried to source a rotor that supported a 55mm pad depth (turned out to be an expensive venture if I decided to do that) or use the 50mm pad... biggest issue realistically is the rear pad has 2mm less material depth than the front pad so will wear out sooner... however it works perfectly as there is minimal loss of pad surface area and because I no longer had pad knock off or any of the other issues all was good..
As a further comparison... here is an old pic I took showing off a few of the pads including LCR brembo... as you can see the Brembo pad while being 50mm deep is not quite as 'wide' as the AP pad...
What are they like? f00king actual amazing!!!... they just bite... I have done a minimal amount of bedding in and they are showing no signs of dropping off... little more to do I think before I try a higher speed/hard stop but I have done a fairly hefty pull up from road legal speeds and it near ripped my face off!! ABS was having a bit of a spaz as there wasn't much heat in the tyres and its a little damp out but the difference is epic!!...
I will have to learn how to drive again... I can brake much later now and have much more confidence in my brakes...
