Was giving the car a clean before the MOT tomorrow, all looking nice and presentable and the boot wouldn't open, assuming I'd got some water in the electrics or similar I used the manual release and found that all worked fine, but only intermittently both the remote and the release button was working but only through some of the range of motion of the boot. Turns our I had an issue with the wiring loom and it had chosen this afternoon to finally give way!
The jury seems to be out on a fault boot lid being an MOT failure, however I wasn't willing to run the gauntlet.
I'm sharing this info to hopefully help someone who has a similar issue. In fact seeing the damage I think the fault which looks to me to be a design issue could affect any of the electrics in the rear boot lid, as a few other wires were close to breaking on mine.
The wires appear to rub on a bolt or maybe just kink whilst the boot lid transitions from open to closed, I don't have a photo from before but it was bad enough to have stripped the fabric tape on small section, broken one wire and cracked the insulation exposing several others. Looking at it I'm, surprised I've not had shorts or other issues before now.
I have effected a temp repair to get it past the MOT (hopefully) and will see what Audi say, I'm out of warranty so I'm sure the answer will be expensive.
If that is the case, given that I've done the hard work to get to the loom already, I'll probably just cut out the affected section and add in some new wires.
