  1. LarrySFU
    LarrySFU The Member
    44
    10
    Hi all,
    Got some faults with my A3. The start/stop doesn't work at all. I'm also having issues with almost all of my exterior lights not working. Another issue is the windows (all 4 of them), they don't respond properly to me pressing the buttons to open and close etc. These are just the noticeable issues. There may be more underlying ones I'm not aware of! Thanks in advance ;)
    I've had it scanned and have been given this. I don't understand it one bit - I'm not very techy.
    Thanks in advance :)
    VCDS
    Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 17.1.3(x64) Data version: 20170203 DS267.2 www.Ross-Tech.com
    Dealer/Shop Name: Workshop Code: 000 00000 000000
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:31:39744
    VIN: WAUZZZ8P9BA166319 License Plate: Mileage: Repair Order: xxy298
    Chassis Type: 8P (8P0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72 77
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010
    ------------------------------------------------------------------------------- Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
    PartNoSW:03L906023M HW:03L906023L Component: R4 1.6l TDI H23 9979
    Revision: --H23--- Serial number: AUX7Z0K4FN90EU Coding: 00114014030501080000
    Shop #: WSC 06314 000 00000
    ASAM Dataset: EV_ECM16TDI02103L906023M 003017 ROD: EV_ECM16TDI02103L906023FL.rod
    VCID: 3068CB826BB813C159-8064
    No fault code found. Readiness: 0 0 0 0 0
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:31:39744 Page 2
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component: ESP MK60EC1 H31 0108
    Revision: 00H31001
    Coding: 1342201209280000C80E04E590220091380800 Shop #: WSC 06314 000 00000
    VCID: 76E43D9AC15C7DF1C3-8022
    ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None
    PartNoSW:8P0820047D HW:8P0820047D Component: J255 Klima Man H08 0060
    Revision: 00H08004 Serial number: 00000000000000 Shop #: WSC 00000 000 00000
    VCID: 316ECE86A8B21AC956-8064
    No fault code found. -------------------------------------------------------------------------------
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:31:39744 Page 3
    Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb PartNoSW:8P0907063G HW:8P0907063G Component: BCM PQ35 M 107 0615
    Revision: 00107 AG
    Coding: 4E000A2FA005F0C0207041E00000015C421A29AA004DC122E4008F800041 Shop #: WSC 06314 000 00000
    VCID: 3878F3A28BC8CB8111-806C
    Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB Component: Wischer AU350 H11 0050
    Coding: 00DD13
    Subsystem 2 - Part No: 8P0 951 177 Component: Innenraumuebe H04 0020
    Subsystem 3 - Part No: 1K8 951 605 B Component: LIN BACKUP HO H11 9005
    Subsystem 4 - Part No: 1K0 907 719 C Component: Neigungssenso 005 0003
    9 Faults Found:
    01038 - Central Locking Thermal Protection
    000 - - - Intermittent Freeze Frame:
    Fault Status: 00100000 Fault Priority: 6
    Fault Frequency: 5 Reset counter: 178 Mileage: 163931 km Time Indication: 0 Date: 2018.03.10 Time: 16:49:36
    Freeze Frame: Term 15 On
    Voltage: 14.30 V ON
    ON
    Term 50 On OFF
    OFF
    01500 - Bulb for Fog-Lamps; Right (L23)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:31:39744 Page 4
    00984 - Left Tail Light (M4)
    Freeze Frame:
    Fault Status: 00101010 Fault Priority: 2
    Fault Frequency: 1 Reset counter: 159 Mileage: 164851 km Time Indication: 0 Date: 2018.04.06 Time: 13:49:20
    Voltage: 12.10 V ON
    ON
    Term 50 On OFF
    OFF
    00927 - Terminal 30 (Right) 011 - Open Circuit
    Freeze Frame:
    00979 - Lamp for Low Beam; Right (M31)
    Freeze Frame:
    Fault Status: 00101010 Fault Priority: 1
    Fault Frequency: 2 Reset counter: 176 Mileage: 165165 km Time Indication: 0 Date: 2018.04.18 Time: 11:57:36
    Voltage: 14.80 V ON
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:31:39744 Page 5
    ON
    Term 50 On OFF
    OFF
    01499 - Bulb for High-Beams; Right (M32) 010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010 Fault Priority: 6
    Fault Frequency: 23 Reset counter: 178 Mileage: 163702 km Time Indication: 0 Date: 2018.03.02 Time: 16:53:01
    Voltage: 11.85 V OFF
    ON
    Term 50 On ON
    ON
    01504 - Bulb for License-Plate Light (X) 014 - Defective - Intermittent
    Freeze Frame:
    01519 - Bulb for Back-Up Lights; Right (M17) 010 - Open or Short to Plus - Intermittent
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:32:39744 Page 6
    Freeze Frame:
    Fault Frequency: 4 Reset counter: 175 Mileage: 165245 km Time Indication: 0 Date: 2018.04.21 Time: 14:47:31
    Voltage: 14.00 V ON
    ON
    Term 50 On OFF
    OFF
    ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
    PartNoSW:8P0959655S HW:8P0959655S Component: Airbag AU1042 H09 0250
    Revision: -------- Serial number: 003JU0020W00 Coding: 30314238303830303037554A305238503053 Shop #: WSC 06314 000 00000
    ASAM Dataset: EV_Airba10AURB4 001001 ROD: EV_Airba10AURB4.rod
    VCID: 52ACA10A057401D10F-8006
    Crash sensor for side airbag: driver side: Serial number: 3572DRB40000DAA06AC4
    Crash sensor for side airbag: front passenger side: Serial number: 3582DRB40000DAA84A87
    Crash sensor for side airbag: rear: driver side: Serial number: 35128RB4000061A5A41C
    Crash sensor for side airbag: rear: passenger side: Serial number: 35228RB4000061A70DAN
    Crash sensor for front airbag: driver side: Serial number: 35547RB4000062E8177P
    Crash sensor for front airbag: front passenger side: Serial number: 35647RB4000062E8157O
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:32:39744 Page 7
    Address 16: Steering wheel Labels: 8P0-953-549.lbl PartNoSW:8P0953549K HW:8P0953549K Component: J0527 H37 0070
    Coding: 0004012
    Shop #: WSC 06314 000 00000 VCID: 46848D5A313CAD7193-8012
    Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H02 0100
    1 Fault Found: 01304 - Radio
    004 - No Signal/Communication
    ------------------------------------------------------------------------------- Address 17: Instruments
    Cannot be reached
    ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 8P0 907 530 C HW: 1K0 907 951 Component: J533 Gateway H43 0311
    Revision: H43 Serial number: 100411F2002126 Coding: 352103
    Shop #: WSC 06314 000 00000 VCID: 3362C48E92AE28D924-8066
    004 - No Signal/Communication Freeze Frame:
    Fault Status: 01100100 Fault Priority: 2
    Fault Frequency: 170 Reset counter: 247 Mileage: 157419 km Time Indication: 0 Date: 2017.12.02 Time: 13:36:09
    ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    PartNoSW:8P0920982H HW:8P0920982H Component: KOMBIINSTR. VDO H01 0091
    Revision: D0H01004 Serial number: AUX7Z0K4FN90EU Shop #: WSC 00000 000 00000
    VCID: 3E74E5BA69ECF5B1DB-806A
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:32:39744 Page 8
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl PartNoSW:8P0959801Q HW:8P0959801Q Component: Tuer-SG H04 0101
    Coding: 0131764
    Shop #: WSC 06314 000 00000 VCID: 499E8666202242097E-801C
    3 Faults Found:
    00912 - Window Regulator Switch; Front Left (E40)
    008 - Implausible Signal - Intermittent
    00913 - Window Regulator Switch; Front Right Driver (E81)
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
    ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 232 3201 Revision: 00H20000
    Shop #: WSC 02069 000 90108
    VCID: 3460C79257A02FE13D-8060
    ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    PartNoSW:8P0959802Q HW:8P0959802Q Component: Tuer-SG H04 0101
    Coding: 0131764
    VCID: 4A9CB96A2524491177-801E No fault code found.
    ------------------------------------------------------------------------------- Address 56: Radio
    Cannot be reached
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:32:39744 Page 9
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb Part No SW: 8P0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H43 0311
    Coding: F30B185A
    Shop #: WSC 06314 000 00000 VCID: 74E00792D7206FE1FD-8020
    Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A Component: J367-BDM H07 0150
    Serial number: 00000000009370402500
    1 Fault Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent Freeze Frame:
    Fault Status: 00110001 Fault Priority: 7
    Fault Frequency: 31 Reset counter: 178 Mileage: 164642 km Time Indication: 0 Date: 2018.03.24 Time: 02:56:32
    ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    PartNoSW:8P4959801F HW:8P4959801F Component: Tuer-SG H04 0050
    Coding: 0131216
    Shop #: WSC 06314 000 1012544
    VCID: 428C914A1D149151BF-8016 No fault code found.
    ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    PartNoSW:8P4959802F HW:8P4959802F Component: Tuer-SG H04 0050
    Coding: 0131216
    VCID: 4382944E020E9859B4-8016
    VCDS
    Self-Diagnosis Log Tuesday,01,May,2018,08:49:32:39744 Page 10
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P1 862 335 HW: 8P1 862 335 Component: FSE_256x BT H41 0650
    Revision: 00000000 Serial number: 00000005371544 Coding: 0001222
    Shop #: WSC 06314 000 00000 VCID: 74E0079217206FE1FD-8020
    2 Faults Found:
    02503 - Output Wire to Radio
    011 - Open Circuit Freeze Frame:
    Fault Status: 01101011 Fault Priority: 5
    Fault Frequency: 1 Reset counter: 237 Mileage: 157419 km Time Indication: 0 Date: 2017.12.02 Time: 13:36:13
    01304 - Radio
    Freeze Frame:
    End-------------------------(Elapsed Time: 02:11)--------------------------
  2. Avatar
    Google AdSense Advertisement
  3. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    4,592
    3,740
    Fake / cloned version of VCDS :(
    Looks like you have some physical wiring issues going on, damaged loom maybe or even an issue with your body control module (09). Gonna need a professional to investigate.
    Tashfeen likes this.
  4. LarrySFU
    LarrySFU The Member
    44
    10
    Is it? How do you know it's fake? I paid him £20 :-( Does this mean the test results are fake?
    Would it be something I could fix with the wiring myself? I've been to a local car electrician and he wasn't sure on what to do so told me to take it to the dealer but thats quite expensive...
  5. DJAlix
    4,592
    3,740
    Can tell via the version number that it’s a fake / cloned VCDS cable. I would be inclined to seek the help of a professional who can check for issues based on the results of a diagnostic scan. What the above information is pointing to could be a pretty big wiring loom issue or indeed a control module issue, I believe it to be the latter which is something you cannot fix yourself unless you have the correct software and tools. Your stop / start issue is not related to this and you need testing via someone who knows what they are doing.
  6. rum4mo
    rum4mo Well-Known Member
    1,773
    408
    I hope that he checked your £20 note. As said above, when you know what to look for, the version number can give the game away.
