Faults after fitting a tow kit to SQ5.
Babyburt
Hi all, I’m after some help with faults that have come up after I fitted my car with a tow kit.
I’ve got a 2017 SQ5 3.0tdi and fitted the bar without any big issues. I purchased the specific wiring kit for the car.
It doesn’t have trailer prep so I had to splice in 3 wires. Having followed all the instructions. When I’ve reconnected the battery I have fault codes showing and some kit not working.
Car is saying the sports diff has a malfunction, TPMS and auto hold brake aren’t working. Stability control light is on.
I have checked the codes with Carista which shows the following,
CAN network gateway:
01044 - Control Module Incorrectly Coded
Engine:
04327
04330
ABS:
01324 - Control Module for All Wheel Drive (J492)
Adaptive cruise control:
01314 - Engine Control Module (ECM)
01316 - ABS Control Module
All fuses are ok. The tow electronics work, I get all the lights on and it shows on the dash.
Questions are, when I get the tow kit coded will the faults go or will I have to get other coding done looking at the above, is the car ok to drive?
Thanks for reading and hopefully some advice.
NHN
Site Sponsor
They will clear once coded.
Babyburt
Awesome, I was hoping they would. I was trying to see if all the faults were on the same ecu, which would explain. Ta for the reply.
